rear end clunk
Old Mar 27, 2010 | 11:49 PM
Riley's Avatar
Riley
Default rear end clunk
My 1980 auto has a loud clunk from the rear end when it shifts from first to second and third. U-joints are good, new trailing arms and half shafts. The differential top mount may need changing but want to ask first as i think that might be a hard job for nothing.
Old Mar 28, 2010 | 12:19 AM
Sidepiper's Avatar
Sidepiper
rear pinion snubber
Old Mar 28, 2010 | 12:24 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Not a hard job at all. I would agree that it is the snubber. You can put the car on jack stands and do the job. Or just put the rear tires up on ramps and do it that way too.
Old Mar 28, 2010 | 02:34 PM
corvetteload's Avatar
corvetteload
And while you are fiddling in the rear area, go to GM parts counter and get posi additive for the rear, do it now.....................
Old Mar 28, 2010 | 03:11 PM
EIGHTY's Avatar
EIGHTY
Old Mar 28, 2010 | 04:34 PM
razman's Avatar
razman
piece of cake........have changed several of them while laying under car in my garage. and, that is probably what you are hearing, very common! Rick
Old Mar 28, 2010 | 05:43 PM
GD70's Avatar
GD70
Also check the drive shaft rear universal, unless that's new as well.
Old Apr 7, 2010 | 05:54 PM
Riley's Avatar
Riley
ok on stands but having hard time getting wrench on top bolt. Any body know the size and how the heck does it fit. I think i may have to bend the wrench once i find the correct size.
Old Apr 10, 2010 | 12:34 PM
Riley's Avatar
Riley
ok removed drive shaft and replace the snubber. Thanks guys the clunk is gone.
Old Apr 10, 2010 | 02:19 PM
razman's Avatar
razman
awesome! isn't it great when a plan comes together?
To rear end clunk
