Trailing arm pivot bolt
Old Mar 28, 2010 | 01:05 PM
DrVincennes's Avatar
DrVincennes
Default Trailing arm pivot bolt
I’m in the planning stage of removing the trailing arms on my 1972. I checked the pivot bolt and nut on each side and both turn easily. Doesn’t look like the sawsall or the torch are going to be needed. I’ve read several threads where guys drive out the bolt with a punch but the bolt is at such an angle, I don’t see how you can get to it to drive it out. After I get it out, it looks like it’s going to be a bit of a pain to get it back in. Not much room to work. The brake line distribution block bracket is right in the way. My questions:
What is the easiest way getting out the bolt? What is the easiest way getting it back in?
Thanks.
Old Mar 28, 2010 | 01:15 PM
Gordonm's Avatar
Gordonm
There is room to get a long punch in there to drive it out. On the way back in I use a long set of needle nose pliers to get it back in. Done this may times with no trouble. Takes a little fishing and you may drop the bolt once or twice but definitly doable.
Old Mar 28, 2010 | 02:50 PM
crossfire1982's Avatar
crossfire1982
Your trailing arm bolts have holes in them near the ends. Fish a piece of monofiliment fishing line through the hole then tie it then fish the line through the trailing arm and mount. Long needle nose pliers or long forceps will help get the bolt started and the fishing line can be pulled to bring it all the way through. a heavier string tied to the head end of the bolt also makes it easier to fish the bolt back if / when you drop it while getting it started. Just cut the string off when the bolt is almost home. The bent pin you see through the trailing arm is just to temporarily hold everything in place till Im ready to fish the bolt through. Of course, the bolt is fed in from the inside with the nut on the outside, this picture tends to imply otherwise but is merely for illustration.
Old Mar 28, 2010 | 06:28 PM
DrVincennes
Thanks Gordonm and Crossfire. That's why I love this forum, there is always somebody who has that better mouse trap.
Old Mar 29, 2010 | 11:30 PM
Kahle76's Avatar
Kahle76
I just did this last week and it wasn't as difficult as it might seem. I did lube the bolt and make sure it slides trough the new trailing arm bushing. I just pushed it though with a pair of needle nose pliers. Fairly easy.
Old Mar 30, 2010 | 09:05 AM
larryg3's Avatar
larryg3
The needle nose pliers are the trick for getting the bolt back in. That is what I used on mine. I like the idea of the string.
Old Mar 30, 2010 | 10:04 AM
Woodsters's Avatar
Woodsters
I too just reinstalled my trailing arms. Lube the bolts with Extreme Pressure grease or even anti-seize. They will slide in with no trouble and hopefully, decades down the road, they can be removed with ease!
Old Mar 30, 2010 | 06:55 PM
68/70Vette's Avatar
68/70Vette
You absolutely must get a set of long needle nose pliers. They are great for this job and many others. You can buy them from Sears (Craftsman). The pliers are about a foot long with really long needle nose jaws (maybe four inch jaws). Craftsman sells two styles: straight jaws and jaws bent about 45 degrees. Get them both. Also I think Van Steel sells them in his catalog.
To Trailing arm pivot bolt
