Horn relay
Old Mar 29, 2010 | 09:45 AM
VetteProject's Avatar
VetteProject
Default Horn relay
Where is the horn relay on a 78 located?
Thank you!
Old Mar 29, 2010 | 09:57 AM
c3corvettes's Avatar
c3corvettes
Should be way up the driver's side floor board area. It should be about 1" blue plastic square looking thing.
Good luck
Old Mar 29, 2010 | 02:29 PM
larryg3's Avatar
larryg3
I have an '81 and when I was looking for it someone told me sit in the car and stick my left hand up the dash and feel around for a small box and to gently pull it down. I was skeptical at first but after I had visually looked for it with no luck I tried it and sure enough I found it.
Old Mar 29, 2010 | 07:13 PM
Duke94's Avatar
Duke94
Horn relay is above the fuse panel. Check this site for all the 78' wiring diagrams.
Gary
http://www.corvetteforum.net/c3/tune.../index20.shtml
Old Mar 29, 2010 | 08:42 PM
gjohnson's Avatar
gjohnson
On my 76 its located right near the fuse box.
Old Apr 2, 2010 | 08:40 AM
VetteProject
I replaced the horn relay and it finally works! It doesn't sound very manly but I'm so happy because it is the cheapest/easiest thing I've had to fix so far.
Thank you for the help!
To Horn relay
