Cigarette Lighter ?
Old Apr 3, 2010 | 12:04 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Default Cigarette Lighter ?
I had my garmin gps plugged into the cig lighter and after a few minutes it wants to shut down. Anybody know what's up with that? Cig light and gps work fine otherwise. Thx.
Old Apr 3, 2010 | 12:12 PM
Lars V2.5's Avatar
Lars V2.5
Cruising
From: At my Bar drinking and wrenching in Boulder Colorado
Have you tried to use anything else with the cig. lighter? Maybe the contacts arn't touching well? With my '69 the ground came off.
Old Apr 3, 2010 | 12:37 PM
78pace's Avatar
78pace
I had similar issue , wanted to charge my phone.....but blew the fuse
posted a question here... basiclly the answer was. Old technology I was told to try an after market set up to plug phone into. not sure if this is your issue but a thought
Old Apr 3, 2010 | 01:22 PM
dar322's Avatar
dar322
yeah i was wondering if old technology was the issue too.
Old Apr 3, 2010 | 03:13 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
The garmin would want to switch off as soon as it loses power from the cig. lighter plug, so I would think that your plug is not secured enough into the cig. socket and when ever it disconnects (even for miiliseconds) your garmin gps will think that you switched off the car and it would switch it self off accordingly.
try to clean the cig. socket with something like contact cleaner and also try to check the electrical connections underneath the shifter panel.
To Cigarette Lighter ?
