soda blasted
Old Apr 3, 2010 | 07:57 PM
ozzyrulesme's Avatar
ozzyrulesme
Default soda blasted
[IMG][/IMG]
I just got my 74 soda blasted. Wow there was alot of paint and primer on it. Took 4 hours!
Old Apr 3, 2010 | 08:00 PM
Lars V2.5's Avatar
Lars V2.5
Cruising
From: At my Bar drinking and wrenching in Boulder Colorado
[IMG]"<img src="http://i976.photobucket.com/albums/ae247/ozzyrulesme1948/74%20vette/102_3269.jpg" border="0" alt="soda blasted">[/IMG]"
Old Apr 3, 2010 | 08:03 PM
ozzyrulesme
[IMG][/IMG]
Old Apr 3, 2010 | 08:04 PM
ozzyrulesme
I got it now.. Thanks!!!
Old Apr 3, 2010 | 10:17 PM
jordan89's Avatar
jordan89
Old Apr 4, 2010 | 09:01 PM
C3 4ME's Avatar
C3 4ME
Now the fun really begins!
Old Apr 4, 2010 | 10:04 PM
MN-Brent's Avatar
MN-Brent
What happens to all the media and paint? Did it end up on your driveway and yard or did they take care of it while blasting or ?
Also what is the ballpark this runs ya?
Old Apr 4, 2010 | 10:46 PM
Bowerss2's Avatar
Bowerss2
how easy is this to do yourself? i have been thinking about it, but i am worried that i will moon crater the fiberglass.
what about the interior/ engine compartment, will i have to take the interior out?
Old Apr 5, 2010 | 09:24 PM
ozzyrulesme
The paint breaks up in little piece. you don't see any of the paint on the ground. the grass had a little tint of white. sweeped up what i could. then just hosed the driveway down with water. It had rain that night.next morning you couldn't tell...
Old Apr 5, 2010 | 09:29 PM
ozzyrulesme
I paid a guy to blasted it, $600 to do it. I had a trap over the engine,and inside the car. Still got dust over it.
Old Apr 6, 2010 | 09:17 AM
jnb5101's Avatar
jnb5101
don't know what brand of epoxy you plan to use, but spi does not recommend using their product on soda blasted vehicles.
Old Apr 6, 2010 | 03:37 PM
Priya's Avatar
Priya
If you wash it well afterwards it shouldn't make a difference, should it?
Old Apr 7, 2010 | 08:11 AM
jnb5101's Avatar
jnb5101
no idea. i used the razor blade and sandpaper technique on mine, so the caution didn't concern me. but it is in BOLD print in their manual.
Old Apr 11, 2010 | 07:09 PM
jb1002x's Avatar
jb1002x
3rd Gear
You MUST use a pressure washer to rinse and scrub with a white brush and use simple green!! Pressure washer is the only way to remove the soda residue from the glass. A simple hose down with the hose isn't going to do it. Usually takes me an hour and a half of scrubbing and pressure washing. Dont do it in the sun and keep it wet untill you are done washing. Let sit in the sun for a good day to dry it out or use an air gun to blow dry.
Be sure the glass is completely DRY! Even after I blow it dry, i let sit in the sun for a day or put it in the booth and bake it (if it is cold out).
Old Jun 9, 2010 | 09:11 PM
ozzyrulesme
[QUOTE=jb1002x;1573726280]You MUST use a pressure washer to rinse and scrub with a white brush and use simple green!! Pressure washer is the only way to remove the soda residue from the glass. A simple hose down with the hose isn't going to do it. Usually takes me an hour and a half of scrubbing and pressure washing. Dont do it in the sun and keep it wet untill you are done washing. Let sit in the sun for a good day to dry it out or use an air gun to blow dry.
Be sure the glass is completely DRY! Even after I blow it dry, i let sit in the sun for a day or put it in the booth and bake it (if it is cold out).[/QUOT
All i did was blow the car down. That was it. Its all good..
To soda blasted
