Headlight switch problem
Old Apr 3, 2010 | 08:28 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Default Headlight switch problem
My dash lights havent worked since I got the car over the winter. Tonight I was taking out the car and put on the lights...BINGO the dash lights came on(I just assumed my bulbs were all out) then I touched the light switch and off they went again! If I wiggle it I can get them back on. Think its a short or something with the switch?? Anyone ever have this problem? Just wondering if I can fix it. Thanks!
Old Apr 3, 2010 | 08:54 PM
Tom73's Avatar
Tom73
I would have to guess that the switch is just worn out.
tom...
Old Apr 3, 2010 | 09:35 PM
ozzyrulesme's Avatar
ozzyrulesme
When i bump my switch my parking lights come on bought a new one. Haven't got around to putting it in.. lol
Old Apr 3, 2010 | 10:37 PM
wills670's Avatar
wills670
You may have a bad switch or just dirty contacts. The dash lights work off of a reiostat (I think thats the proper name but unsure of the spelling) when you turn the switch to the right it makes the lights go dim but when you turn to the left they go brighter and then you turn on the dome light.
Work the switch left to right mutiple times and see if it gets better.
Old Apr 3, 2010 | 11:04 PM
Ret.Horsecop13
Thanks everyone! I'll give it a try.
Old Apr 5, 2010 | 12:00 PM
jaki30's Avatar
jaki30
Default New switch time
If the lights only work when you fiddle with the switch it is probably the rheostat for the dash lights. When they come on can you dim the dash lights or do they look like they are on bright? The reostat cily can break near the rivet. The lamps will only work when you use the dimming part of the switch and can bridge the break.
Old Apr 6, 2010 | 01:30 PM
joewill's Avatar
joewill
it works by completing the circuit to ground, make sure your switch is grounded.. and as stated above.. spend about 5 minutes rotating it with your fingers back and forth, off and on.. hundreds of times.. this should wear off any corrosion or rust on the contact
Old Apr 6, 2010 | 08:35 PM
Hammerhead Fred's Avatar
Hammerhead Fred
The trick above works and you can also try pulling the switch out to the "on" position for the headlights and then gently push in on the **** "just a bit" and sometimes the dash light rheostat pickups will then contact the resistor coil. As the switch ages either the coil breaks as described above and/or the spring that holds the contact pickup against the coil loses stiffness. Pressing in a bit will close the gap.
Old Apr 7, 2010 | 12:05 AM
Collin72's Avatar
Collin72
Cruising
Had the same experience in my 72, just put in a new switch, relatively easy and not too expensive, no more problems after that
Old Apr 7, 2010 | 01:54 PM
pleasants9's Avatar
pleasants9
my dashlights are like that too, someitmes they will go out I just have to toggle the dimmer that adjusts their brightness and eventually i find a sweet spot that turns them back on. I think the switch just needs replacing
Old Apr 7, 2010 | 06:51 PM
Ret.Horsecop13
Thanks for the help everyone. I have tried all the remedies, it still isnt working right. I think I'll just change the switch. Thanks again!!!
Old Apr 12, 2010 | 09:26 PM
ozzyrulesme
Put the new switch in and fixed alot of the promblems. dash lights work, can dim them, head lights go up and down. VERY HAPPY!!!
To Headlight switch problem
