help me if you know the answer
Old Apr 9, 2010 | 08:32 PM
Andrew74's Avatar
Andrew74
Default help me if you know the answer
I have a 74 vette 350.. I need to know how long the speedometer cable is..I threw mine away b/c kragen said they had one that would fit little did I know their cable was 5feet long half the length of my car.. If you can help pls respond
Old Apr 10, 2010 | 08:25 AM
BKarol's Avatar
BKarol
If you have a 4spd Ecklers claims it should be almost 6ft long for a one piece.
http://ecklers.com/product.asp?pf_id=A3510&dept_id=1207
Old Apr 10, 2010 | 10:42 AM
Paul L's Avatar
Paul L
The Paragon catalogue says 70", 1969-77 w/o cruise control.
Old Apr 10, 2010 | 02:30 PM
gbvette62's Avatar
gbvette62
You don't say whether you have a 4 speed or automatic!
4 speeds used a one piece cable at 70" long. Automatics originally had a 2 piece cable that coupled together just below the master cylinder. I think the auto cable was about 82" long (one cable 40" long & the other 42"???) when screwed together. The current one piece, 70" long, 4 speed cable will work fine as a replacement for the 2 piece auto cable.
Unless my math is wrong, at 70 inches, it sounds like you need about a 6 foot long cable!
To help me if you know the answer
