1975 Brake Booster Question
Old Apr 11, 2010 | 03:26 PM
vette54728702's Avatar
vette54728702
Default 1975 Brake Booster Question
I was replacing the master cylinder on my '75 when I noticed corrosion on the booster itself. In the center (front) of the booster is the shaft that comes out of the booster and pushes into the master cylinder... the seal around the shaft as it comes out of the booster is bad and that is where my leak was.... Now, I can't find a new seal... what do I do?
Old Apr 11, 2010 | 03:50 PM
Phil Zell's Avatar
Phil Zell
If you don't have a buddy that sells parts you are going to have to buy a new booster.
Old Apr 11, 2010 | 04:04 PM
vette54728702
Evidentally the seal itself isn't available... I've tried the local parts stores...
To 1975 Brake Booster Question
