Power antenna
Old Apr 17, 2010 | 10:59 AM
clauer's Avatar
clauer
1st Gear
Default Power antenna
I have replaced my antenna in my '78 with a new power one. The problem is it will go up but not down when the radio is turned off. Any help mould be appreciated.Thak you
Old Apr 17, 2010 | 11:11 AM
spedaleden's Avatar
spedaleden
Make sure the relay is working. It sounds like antenna or relay. If you have a repair manual make sure the gray, green and white wires are seeing power and ground at the appropriate time. If they are then you will need a new power antenna.
Wilcox has the factory replacement
Old Apr 17, 2010 | 02:24 PM
mydejavooo's Avatar
mydejavooo
See, and I just went the other way on my 80....pulled out the Delco unit, and got a fixed antenna....so I don't have to mess with any more relays than I absolutely have to! Haven't decided if I should just ****-can the old unit or sell it.
Deja
To Power antenna
