'75 brake booster removal?
Old Apr 17, 2010 | 04:15 PM
vette54728702's Avatar
vette54728702
Default '75 brake booster removal?
I've removed the master cylinder... now, How do I remove the booster that needs replaced?
Old Apr 17, 2010 | 05:01 PM
jordan89's Avatar
jordan89
You have to remove four nuts inside the car behind the firewall. It's a PITA, but it can be done. Get a long extension and one of those flexible joints for the sockets. It's a tight space, so you need to be patient.
Old Apr 17, 2010 | 05:10 PM
MN80Vette's Avatar
MN80Vette
Try the Advanced Search on the C3 Tech forum. There have been several threads on the subject that include details and pictures of the ratchet-extension-ujoint combo commonly used. Definitely remove the drivers seat so you can lie on your back with your feet in the storage area.
Old Apr 17, 2010 | 06:02 PM
vette54728702
OMG ! Sounds like I'm in for some real work replacing this booster... UGGGGH !
Old Apr 17, 2010 | 11:05 PM
rudolph schenker's Avatar
rudolph schenker
Yes! Prepare to suffer! Probably one of the biggest PITA's
Old Apr 18, 2010 | 09:13 AM
guappy's Avatar
guappy
It makes it eaiser if you take the seat out but it is still a PITA Good Luck
Old Apr 18, 2010 | 12:16 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
I removed mine on my '79 a couple of weeks ago, have the dash, seats and steering column out and it was very difficult to get all of those nuts off, big time PITA!
I had an extra nut on the lower right bolt that was holding up a wire harness. When I couldn't get the booster off I finally discovered the extra nut.
Old Apr 19, 2010 | 12:34 AM
loquinho's Avatar
loquinho
I replaced that when redoing my brake system. I didn't remove anything extra to get it out. For me, it required a frankenstein socket wrench assembly, and me sitting upsidedown in the driver's seat, t-tops removed, with my feet out above the roof. Then, it's just a lot of tiny, tiny turns of the socket wrench (1 click at a time at one point) to get them out. It's only 4 nuts, but it takes patience. Once it's out, slip it off, new one on, then back into position to get the nuts back on the new booster. Have fun
To '75 brake booster removal?
