differential removal help
Dad and I are in the process of replacing the u joints in the half shaft and drive shaft. We would also like to take the differential out and have it checked etc. How do you remove this? Just looking at it, It appears to have 4 bolts coming through the top of which I can't figure out how to remove. Any articles or step by step help would be greatly appreciated.
you need to remove the spring, jack up the ends and remove end bolts.
put your jack 1/2 inch below diff housing so it doesn't fall on the floor.
Glenn
To the OP and Dad: Congrats.
Now you guys are a C3 IRS-axle-pullin' veterans. That looks a lot like most of us once we get them away from the frame.
There's a few pieces I scraped & sand-blasted for reuse: crossmember, rear cover, chin bracket, and misc fasteners. The offset TA's and all those VB&P pieces come powder coated new. I replaced the diff as an assembled unit [to save the #'s matched original for a future restore]. It's setup & stuffed w/new gears, posi, bearings, seals. Half-shafts, u-joints, yokes are new as are the rotors. X-member end cushions are new (they're pricey).
Then anything not p-coated was carefully washed w/hot, soapy water, dried, & painted. I replaced some fasteners w/new ones; focused on units that were out-of-spec.
On mine, I repld stuff to accomodate wider tires and a little autox'ing. Have a TKO600 too. After looking over what you have, you'll probably need seals, gaskets, grease & gear oil. Anything more than that depends on how many Dead Presidents can you afford to trade for what you find needing replacement. Good Luck.
...and Thanks Glenn. For now, it's fun to look under there and know I gave it it a good shot.
Seems like you could do this for a street car also. You'd have to pull the carpet back each time you wanted to drop the diff and you'd have to find some grommets or some sort of a cover so later water would splash up when driving. Even for a stock purist, no one would ever know what you had done when you laid the carpet back down.
