Question about RH courtesy light bracket
Old Apr 29, 2010 | 09:42 AM
Mashman's Avatar
Mashman
Default Question about RH courtesy light bracket
Hi there,
My passenger side courtesy light has always just hung up under the dash (wrapped around AC ducting). I always planned on getting a proper bracket, but it was a low priority.
Yesturday, I pull the kick panel to swap out the speaker, and low and behold, there's a shinny bracket for the courtesy lamp.
My problem is this - I've looked at the AIM, and under the C60 (A/C) pages, it shows where to put the bracket - but I can't tell where it is showing to put it. I appears to put it 2.48" up on something, but I can't tell what the something is.
Thanks,
Matt
Old Apr 29, 2010 | 10:02 AM
MakoShark72's Avatar
MakoShark72
Originally Posted by Mashman
Hi there,
Thanks,
Matt
Matt,
On my 72, which, when I bought it, was pretty much ALL original, the passenger side courtesy light bracket screwed into the top of the kick panel..Mine too was hanging down when I bought the car (IIRC) but the hole was there, so thats where I mounted it when it went back together..
Old Apr 29, 2010 | 10:15 AM
oldsarge's Avatar
oldsarge
It screws into the top of the kick panel. There is pictures in the aim, should be in the electrical section, or interior parts.
Old Apr 29, 2010 | 01:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It probably uses the kick panel trim screw.
Old Apr 29, 2010 | 01:19 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
It uses a pop rivit from the back side on later C3s. Worth a look...
To Question about RH courtesy light bracket
