when I remove the auto neutral safety switch can I just unplug it and let the wires stay where they are at, with the exception of the 2 purple wires that I will route to the clutch pedal switch ?
Anybody got the black/orange tracer vaccum line that runs from a T above heater to the passenger side vent diaphram , seems a mouse moved in last winter and did not like it there and chewed it into.
Thanks All
Sorry no help here, but I am sure others will chime in. You do seem to be having a great deal of trouble with "mice" these days though!
How long of hose do you need on the hose? I have some original hose sets that have been cut from and may have one for you! Just post how long and if I do I'll send it to you Monday...
As for the re-route.. you'll be fine with the way you are doing it. just make sure you use the pedal switch.. I hate cars that start all the time..
As for the mouse.... I'd suggest a trap, but that might hurt your fingers!
Willcox
Thanks for getting back, I lucked out yeaterday and found the correct vac hose. All is well
