Need dash picture
Old May 4, 2010 | 04:34 PM
Phil Zell's Avatar
Phil Zell
Default Need dash picture
can anyone post a pic of a 69/76 with the lower dash pad (driver side) removed. I am doing the auto/to 4 spd conversion and putting the dash back together and forgot just exactly how the harness feeds up from under the dash. the main wires I am concerned about are the ones that feed the steering column that are bundled together, how are they routed ? any pics ?
The main harness comes up on the left side and around over the top of speedometer and tach, the wires that drop down in a bundle is the one I need to know it's routing.
Confused
Old May 4, 2010 | 08:49 PM
Phil Zell's Avatar
Phil Zell
bump
Old May 5, 2010 | 02:41 AM
KSM's Avatar
KSM
This is the only one I could find on my 71 tear down. The wires just above the flash light I will will check tommrow......I think the are at the bottom of the panel....it is the flasher harness and the floor light I will look tommrow.
Hope it helps
Old May 5, 2010 | 08:31 AM
Phil Zell's Avatar
Phil Zell
Thanks KSM for the reply, The routing I need to see is behind the speedo/tach. There is a busser for the key that is located in the harness and about an inch right of that there are wires that run down between the speedo/tach these are the wires I am trying to find out where to route.
Old May 5, 2010 | 09:49 AM
KSM's Avatar
KSM
Sorry it was late when I posted........I missed what side you needed.
maybe these will help
Old May 5, 2010 | 10:36 AM
GD70's Avatar
GD70
Here's a few from underneath looking up. Hope this helps some.
Glenn
To Need dash picture
