best coated headers for C3
Old May 16, 2010 | 09:33 AM
onebadmofo's Avatar
onebadmofo
Default best coated headers for C3
I looked in the search and could not find what i had read a few months earlier....... I have a 76 SB w/ a 4 speed and looking for Ceramic Coated Headers and i thought that some guys were happy with Summiit Brand headers or maybe it was another brand that they bought out of Summit.
Any pics or part #'s would be great......OH and how hard were they to put on?
Thanks,
Sid
Old May 16, 2010 | 11:31 AM
dbeall1968's Avatar
dbeall1968
I bought Flowtech, silver ceramic coated. They rusted before a year was up, and I only ran the car for 5 minutes in that year. I am very unhappy with them, and now headers are back on my "to do " list.
Old May 16, 2010 | 01:14 PM
toddalin's Avatar
toddalin
You want the best, you want Doug Thorley headers.
Old May 16, 2010 | 02:05 PM
zapper295's Avatar
zapper295
I just bought a 76 L48 4-speed. Who makes the "best fitting" with ceramic coating? I don't want to get a coated header and then have to beat on a tube for it to fit. Then mess up the coating trying to get it to fit. Just thought I'd add that also.(fitting) Do Doug Thorley headers fitt nice? Without any mods.
Old May 16, 2010 | 04:15 PM
Bric's Avatar
Bric
I bought the Stan's Tri-Y's with the ceramic coating (2000deg.). Came with everything I needed to mount including graphite gaskets. They are pricey.... I paid $740 shipped to my door. I'm VERY happy with them!!
They are of very high quality and fit with no problems. My buddy bought a pair of Super comps for his 74 at the same time I bought these. No comparison. The Hookers aren't even in the same ball park. Just depends on what your budget is.
Here is the link:
http://www.stans-headers.com/gm_headers.htm
Old May 16, 2010 | 08:09 PM
toddalin's Avatar
toddalin
I have them on a '64 and they fit great. They required absolutely no dimpling anywhere and leave plenty of clearance for the starter and steering box.
The most "iffy" point is that the flange that meets the downpipe is very close to the firewall at the driver's floor board (plenty on passenger side). I just laid a piece of aluminum "foil" along that spot on the firewall.
I imagine that the fittling on a C3 around the floor area would vary from mine a bit.
Old May 16, 2010 | 08:10 PM
PowdercoatBill's Avatar
PowdercoatBill
I do ceramic coating on headers. I'll tell ya you should buy an uncoated set of headers, trial fit and run them before coating. If you need to dimple a tube for clearence, you don't want to beat up an expensive coating. Also it'll let ya tune the car. nine outta ten times people will put a header on an untuned car and dull the coating out in the first ten minutes. If it runs too fat, or too lean it'll dull out.
On another note, I just bought, coated and installed a set of Hooker competition headers on my wifes 77. I was amazed at how easy they went in! I cut a three inch section out of the header flange between the tubes to help prevent leaks. Plus I didn't have to remove the dip stick tube!
If you have any other questions about header coatings, feel free to ask.
Old May 17, 2010 | 10:18 AM
69ragvette's Avatar
69ragvette
Default headers
I will not recommend hookers ceramic coated.my eng was tuned ran in the headers were installed and the car sat in a dry body shop for a year every time I looked at the car I saw more rust contacted hooker they told me the car must have sat in the weather for a long time. BULLSHYT! I paid 650.00 for crap I never buy from company twice when when I get screwed. Go STAINLESS I would rather have a little blue than rust.
Old May 17, 2010 | 12:29 PM
JET-HOT's Avatar
0JET-HOT
Former Vendor
Rather play it safe. It might cost you a little more in doing it that way but well worth it. Although at the same token if using our coating putting clearance dents in the tubes would not be an issue as our coatings will take close to a 180° bend before you damage the coating itself.
Just personal opinion though I would rather test fit prior to coating.
Old May 17, 2010 | 01:15 PM
earlyj's Avatar
earlyj
Default sanderson cast iron headers
I'm running Sanderson Cast Iron headers. Had to open them up to match up to the "D" port on the Fast Burn Heads.
I went with the Cast Iron because they are quiet and dont "ping" like tube headers and they seem to hold up well. been on the car since 2003.
coated with cast blast but now need another coat after 7 years.
Old May 18, 2010 | 12:22 AM
Racer11's Avatar
Racer11
I have Hooker ceramic coated headers and side pipes,,,,,the headers are doing fine after 3 years,,,my problem are the small rock chips that are on the pipes just behind the front tires,,,,in a couple more years I will need to get them redone.
Old May 18, 2010 | 02:00 PM
RunningMan373's Avatar
RunningMan373
The Flowtech ceramics from summit fit perfectly, no significant rust after about a year, but your experience may vary. I like them, they fit right out of the box with no dimpling on a manual, easy install from below. Can't go wrong for 265.
Old May 18, 2010 | 02:15 PM
toddalin's Avatar
toddalin
Already appears to have some rust along the flanges.
Old May 18, 2010 | 02:30 PM
RunningMan373
Yes, they've been on a year. cost 265, fit perfect out of the box, there is some tiny rust spots along the flanges, the car is kept outside. good eyes!
To best coated headers for C3
