Trans qustions?
Old May 16, 2010 | 07:14 PM
TODWEELZ's Avatar
TODWEELZ
Default Trans qustions?
I've got an 80 L82, when I accelerate from a stop with car in drive[3], its a dog, very slow to take off,[ it has been timed properly per instructions found here] if I run it through the gears manually it runs perfect, also kickdown is not working at all, cable seems to be in adjustment, w/ wot the cable is taught and fully engaged. Is there something else I can check, vacuum modulator?, torque converter, any constructive thoughts would be great. Thanks, Todd
