Bumper nuts
Old May 18, 2010 | 09:13 PM
texaswilkins's Avatar
texaswilkins
Default Bumper nuts
I just got a 72 project car. I'm looking things over and learning a new car. The bumpers have brackets with nuts on the back of them. Is there a way to replace those nuts?
Bill
Old May 18, 2010 | 09:45 PM
72LS1Vette's Avatar
72LS1Vette
Do you mean the nuts that are welded on to various brackets? You can always grind them off and weld on new ones, but it might be a lot easier to just get some thread chasing taps and run them though the existing nuts. If they are totally hogged up you can drill through them and use larger bolts.
The bumpers on a chrome-bumper car don't offer a lot of crash protection to begin with so replacing nuts isn't going to help much from a safety standpoint. If you are doing a NCRS-type restoration then you would want to grind/weld on new nuts.
Rick B.
Old May 18, 2010 | 09:55 PM
texaswilkins
On the ends of the bumpers are "C" brackets with both ends welded to the bumper. In the middle of that there is a nut welded to the back side of the "C". One of those nut's is gone. I don't see room to weld behind that bracket, just wondered if someone else had already dealt with it. Still learning.
Bill
Old May 19, 2010 | 11:47 AM
Duke94's Avatar
Duke94
You mean these? Never had to fix one, but it's really tight. Looks like if you use a square nut you could tack it at 2 sides. That's really all it takes.
Gary
Old May 19, 2010 | 12:17 PM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
If the nut is impossible to remove, missing entirely, and cannot be tapped,then buy a hex nut that is correct for the bolt, select a drill with a diameter the size across the points on the nut and drill out the hole. Drive the nut into the hole with a bolt inserted into to nut and then tac weld in in place. Not for NCRS cars but will function properly.
Virginia Vettes
Old May 19, 2010 | 09:30 PM
texaswilkins
Thanks Gary, nice picture. Now I'm off looking for a big square nut.
Bill
To Bumper nuts
