Stupid Spal Question
Old May 22, 2010 | 09:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Stupid Spal Question
After installing my dual Spal fans, I set them up to come on with the ignition. I now want to hook them up to the temperature switch included with the kit, which I installed in the head when I installed the motor. Trouble is, I don't have a fitting to hook the relay switch wire to the thermostat switch. What are people using? Seems like a very small post so I doubt that I could find a nut small enough. Is there a push on fitting of some kind? :o
Old May 23, 2010 | 12:09 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Connector? Why aren't you soldering these important wires together?
Old May 23, 2010 | 01:41 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I believe he's talking about the connector that slides on to the sending unit that is mounted in the block/head.
There are different types but normally the connection point on the harness is a push on friction fit plug (normally elbow shaped) that slides onto the threaded stud sticking out of the sending unit. Messing with a nut on that stud, I agree would be tedious. Good luck.
Terry
Old May 23, 2010 | 11:50 AM
CA-Legal-Vette
Terry
That's exactly right. I'm looking for the push on connector.
Old May 23, 2010 | 12:18 PM
noonie's Avatar
noonie
Why don't you post a pic of what you have, there are several different styles of terminals on temp switches.
Old May 23, 2010 | 12:47 PM
CA-Legal-Vette
Here's a pic of the kit that I got. It's from the DeWitts website and may also explain why I'm having a problem that others haven't.
If you look closely, I think that there's a nut on the end of the sender. Mine doesn't have one. If that's the case, it's pretty easy to deal with.
Can anyone confirm that their sender came with a nut on it?
Old May 23, 2010 | 01:22 PM
CA-Legal-Vette
Found a better pic with the nut in place. Looks like the solution is simple after all.
To Stupid Spal Question
