71 ignition problem
Old Jun 4, 2010 | 12:18 PM
71 Custom's Avatar
71 Custom
Default 71 ignition problem
I have a 71 corvette and had a 77 T&T column installed years ago. Getting it back on the road after nearlt 20 years. I had a small capacitor fall out from under the dask. Looks like a radio capacitor .5 mpf, cant find any bare ware or wear it came from.
Anyone got any ideas ???
Old Jun 4, 2010 | 12:21 PM
RicK T's Avatar
RicK T
You need to ask in the C3 Forum:
http://forums.corvetteforum.com/c3-general-119/
Old Jun 4, 2010 | 01:04 PM
71 Custom's Avatar
71 Custom
I thought I was in the C3 general forum asking ???
Old Jun 4, 2010 | 04:38 PM
Phil Zell's Avatar
Phil Zell
You are correct
Back to the top for you
Old Jun 4, 2010 | 04:58 PM
...Roger...'s Avatar
...Roger...
Is it 2 wire or 1 ? There are several caps under the dash. I know I can't think of all of them.
There is 1 on the brake light switch,1 on the 12 brown wire at the ignition switch,1 behind the clock , might be 1 on the ammeter ,1 on the hazard flasher and 1 on the turn flasher. I'm sure there are probably more.
Old Jun 5, 2010 | 09:13 AM
Duke94's Avatar
Duke94
I'd bet it's the one from the stop light switch. It kind of hangs there and looks like bubba installed it even though GM did.
Gary
Old Jun 5, 2010 | 09:23 AM
...Roger...
Getting old is hell , I know I sometimes get lost in my own house.
Old Jun 5, 2010 | 11:01 AM
71 Custom's Avatar
71 Custom
Roger
Its 1 wire and the numerous schematics I have only show one on the 12 brown.
my wiring is all jacked as i have a 77 interior in a 71 and it had sustained a small dash fire whem i purchased. I am try to get it to the point wher everything works and continues to work. Currently countless hours spent on tracing wires and schematics are less than perfect. Can you tell me the purpose of all thes caps ?? is it just to suppress radio noise ???
thanks again
Old Jun 5, 2010 | 11:02 AM
71 Custom's Avatar
71 Custom
yup that was about the location but i found no other wires hanging. what is its purpose
Old Jun 5, 2010 | 12:13 PM
...Roger...
Yep just radio noise suppression. Wouldn't worry much about the cap but if the wire is still sticking out of a connector that broke off the cap it could be hot and cause some problems.
To 71 ignition problem
