steel leaf spring
Old Jun 6, 2010 | 08:48 PM
tomgallucci57's Avatar
tomgallucci57
Default steel leaf spring
i did the search,found that steel leaf springs are getting hard to find.its sunday so i couldnt call the venders. i will on monday.i have a 68 327 4 speed,300 hp.,havent actualy counted the leaves yet,7 or 9,really dont want to go with composite,price and orriganility is where im at.anyone recently buy a steel spring,and like the ride heighth.reason for this,owned the car for 5 months,noticed it sat a bit low in rear,with a full tank i can see about an inch between top of tire and outer wheel well,or the body,plus it really jumps or is unstable over mild bumps in the road.vbp or van steel,or willcox,speed direct,etc. availability,,is it an issue. thank you all,,ill be back,,,,,tom...ps,it might take awhile. what,,i need shocks too?
Old Jun 6, 2010 | 09:20 PM
TimAT's Avatar
TimAT
Depending on where you live, there is very possibly a spring rebuilder. If you're looking to stay with a steel spring, the vendors have them too. There used to be 3 or 4 spring shops in Kansas City, but they're down to 1 I know of now. It's like finding a good old-time mechanic- they're either retiring or dying off. And in the world of spring shops, nobody wants to (a) work that hard, or (b) learn enough about metallurgy to be able to heat treat them properly to get the right spring rate. I think (a) is really the correct answer. It's some really heavy work- most of the business is big truck springs.
Old Jun 7, 2010 | 12:02 AM
1975greenconvertible's Avatar
Almost all new steel leaf springs are being manufactured in Malaysia or India. I personally wouldn't trust them to be durable over the years. I believe Duntov Motors was selling American made reproductions with the curled leaves. I was able to find a old stock Canadian made spring last year at Carlisle for $150 and it seems to be working great. You should change your shocks at the same time too. Its cheap, easy, and will extend the life of your new spring.
Old Jun 7, 2010 | 12:55 AM
Solid LT1's Avatar
Solid LT1
Eaton spring in Detroit can fix you right up with the best steel springs out there. You 327 SB 68 had a 9leaf spring stock but, the 7leaf F-41 spring is what I use on my LT-1 cars, you would need to balance it with 480 in/lb or 550 in/lb front springs for proper handling. Mike Eaton could help you out with proper front/rear spings for your Vette.
Link: http://eatonsprings.com/
Old Jun 7, 2010 | 09:09 AM
tomgallucci57
thanks gentlemen,im looking into these venders,have a good day,tom.ps i live in cleveland,ohio
Old Jun 7, 2010 | 09:25 AM
mayberg's Avatar
mayberg
Ditto on Eaton Spring - I've got one. It's got the correct shape to the ends and works great for me.
My advice is to avoid re-arching your spring - for me this was a big waste of time and money and effort.
Old Jun 7, 2010 | 10:11 AM
tomgallucci57
well i just got off the phone with eaton,225.oo,9 leaf plus 33.oo shipping,,,duntov had a message,,,didnt leave one. also eaton has front springs for 159.95,,,,ill go with eaton,,again this forum is beautiful,thank you all
Old Jun 7, 2010 | 10:35 AM
noonie's Avatar
noonie
Guldstrand has theirs made in California.
If having one made, even by Eaton, consider geting the lower leaf a hair shorter.
Old Jun 7, 2010 | 11:01 AM
tomgallucci57
a hair shorter to keep the rear wheels in check? sounds reasonable. but after doing more searches im starting to wonder if my bouncing buggy rear end is only in need of some desent shocks,,,how do i know if my leaf spring is worn out,,,,,put on shocks first? and see.
Old Jun 7, 2010 | 11:17 AM
noonie's Avatar
noonie
I would.
Bouncing is a sign of bad shocks.
Old Jun 7, 2010 | 11:28 AM
tomgallucci57
ok,one more thing,my leaf spring lies completly level with the full tank of gas and spare tire,does that sound normal,,,theres no bow at all,,thanks
Old Jun 8, 2010 | 08:56 AM
mayberg's Avatar
mayberg
....my leaf spring lies completly level with the full tank of gas and spare tire.....theres no bow at all
As long as it doesn't "smile", you're probably OK for now.
Old Jun 9, 2010 | 10:57 AM
tomgallucci57
i ordered a nine leaf from eaton spring a few days ago,i probably wont get the bilsteins,too pricy.are monroe sencatrac gas any good 30.00 each or kyb 30.00 each or gabrial gas 26.00 each or sachs 27.00 each,,,thank you all very much,,,tom
To steel leaf spring
