air cleaner
Old Jun 8, 2010 | 03:49 PM
vfrancisco's Avatar
vfrancisco
Default air cleaner
I have a stock 77 L82 and was wanting to put a round 360 degree air cleaner on but can't find one for a 77. Will one fit and if so which one should I go with? thanks vince
Old Jun 8, 2010 | 05:16 PM
gbvette62's Avatar
gbvette62
The stock 68-72 14" open element air cleaner should drop right on, along with any number of aftermarket units. The repro OEM ones look great, were designed to work on a Q-Jet and only cost about $100.
I don't know if you'll see any gain in performance by replacing the stock dual feed unit with an open element one, but if your interested in appearence it's the way to go. The original L-82 air cleaner draws cool outside air into the air cleaner. An open element one is going to be breathing the very hot under hood air, especially at the higher temps that the 77 engine runs at. You may find cold start up and run suffers some too, without the stove pipe feeding warmed air to the air cleaner. If you just want to dress things up, you can also by a chrome lid for your stock unit for about $39. I'm not saying don't do it though, many others have and love it.
Old Jun 9, 2010 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by gbvette62
The stock 68-72 14" open element air cleaner should drop right on,...look great, were designed to work on a Q-Jet and only cost about $100....
Go retro chrome.
Old Jun 9, 2010 | 01:22 PM
vfrancisco's Avatar
vfrancisco
the look is really cool. was that a picture of an 80 vette and did you make a change with the place where it attched to the fan shroud or what ever that is called.
Old Jun 9, 2010 | 01:31 PM
Easy Mike's Avatar
Easy Mike
Nope; stock 69 350hp. The air cleaner will fit your L-82. If memory serves, the snorkel ducting for your L-82 willl come off after you remove the sheet metal screws.
Old Jun 9, 2010 | 01:32 PM
gbvette62's Avatar
gbvette62
That looks to be a 69 350/350hp car with the original stock 14" open element air cleaner, to me.
Old Jun 10, 2010 | 09:28 AM
vfrancisco's Avatar
vfrancisco
thanks i wasn't sure if it would look and operate ok with the ducting off
Old Jun 10, 2010 | 10:02 AM
GD70's Avatar
GD70
Not the stock lid though. The original lid has a larger, deeper bowl area where the wing nut screws down.
Old Jun 10, 2010 | 10:16 AM
Easy Mike's Avatar
Easy Mike
You'll be fine. No snorkels or ducting on the earlier cars. The open element air cleaner will be a little louder than the snorkel can, BUT it'll sound good.
Old Jun 10, 2010 | 02:37 PM
BKarol's Avatar
BKarol
If you are looking for a pic this is a 78 L82 with an Edlebrock 14" and a K&N @2 1/4 inch filter.
Old Jun 11, 2010 | 01:23 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
for what its worth i just went the other way.......from the round open air element unit to the dual snorkle and i can tell the difference in how the car performs. i do have a modifed engine and it really likes the cool air coming in.
you can use the edelbrock filter element from a local auto parts store if you use the black plastic spacer that is available (usually there are 3 in the pack) and cut off the top lip around the front of the carb by the linkage. the base of the air filter will sit on this and life will be good.
Old Jun 11, 2010 | 02:54 PM
vfrancisco's Avatar
vfrancisco
thanks for the info. that gives me more to think about. i'm not sure which way i will go
Old Jun 11, 2010 | 04:06 PM
thegazman's Avatar
thegazman
Default thegazman
Here's my air cleaner on a 1979 L-82 with a q-jet carb. I used a 14" K & N air filter with an off set/dropped aluminum base I bought off of e-bay.
To air cleaner
