'75 T-Tops
Old Jun 17, 2010 | 09:23 PM
OHStingray75's Avatar
OHStingray75
Default '75 T-Tops
Hey,
Should the t-tops for this model have gaps wide enough to run your thumb through? (This is when you're sitting inside and looking up at the roof)
As soon as my camera is fixed I'll try and get some pictures up.
I'm sorry if the question's pretty funny...I'm not the best at describing many things.
Old Jun 17, 2010 | 09:45 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Through what?
If you can stick a finger through to the outside, you've got a bad problem.
Old Jun 17, 2010 | 10:25 PM
blckslvr79's Avatar
blckslvr79
Body line gaps???
Not unless you have small hands.
Maybe 3/8 inch max?
The tops are adjustable.
Old Jun 18, 2010 | 01:09 PM
OHStingray75
No, no, I can't stick a finger all the way to the outside...they're gaps...and I DON'T have small hands!
I plan on consulting a few manuals from the library...I just wanted fellow Vette head opinions first. And like I said, I'll try and get some pictures up asap.
Old Jun 18, 2010 | 01:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Possibly not the best pic for illustration purposes, but these tops fit well. Gap is even front to back and about 3/8" to 1/2". Trailing edges are flush with the halo panel.
69 shown. 75 would fit the same.
Old Jun 18, 2010 | 05:46 PM
stingraymyway
We're going to have to see pics of this.
Has the car been in a wreck?
Old Jun 18, 2010 | 08:26 PM
OHStingray75
Not that I know of. I don't know how the previous owner treated it as far as driving is concerned. And yeah, I promise to get some pics on here as soon as my camera is off the fritz.
Mike: the exterior is fine, it's the interior that I'm concerned about. The driver's side top appears to be on completely, while the passenger side top has a gap, thumb-width separating the center latch from the area where it's supposed to be inserted to.
Old Jun 18, 2010 | 09:13 PM
stingraymyway
Are you sure it's in the right position?
To '75 T-Tops
