please help with 82 crossfire
Old Jun 18, 2010 | 10:06 PM
chadw's Avatar
chadw
Default please help with 82 crossfire
my fans not kicking in and it's overheating, if anyone could help me with a starting point to start looking it would be greatly appreciated
Old Jun 18, 2010 | 10:50 PM
Attfay Elleybay's Avatar
Attfay Elleybay
temp. switch? If you put 12v to the fan does it come on?
Old Jun 19, 2010 | 09:21 AM
markdtn's Avatar
markdtn
good place to start
Old Jun 19, 2010 | 09:11 PM
crossfire1982's Avatar
crossfire1982
The temp switch for the fan is located on the passengers side of the block. You can trace the wires back from the fan itself to the switch which is screwed into the block. The switch merely completes the electrical circuit to the fan when the switch reaches a preset temp. You can "jumper" the connector to complete the circuit and see if the fan actually works. If the fan works when "jumpered" Id say your temp switch needs replacing, they are available at all the vette vendors.
Old Jun 19, 2010 | 10:59 PM
terry82's Avatar
terry82
is your clutch fan working?has the radiator been cleaned in long time [outside and inside]the electric fan does not come on until about 230degrees its a back up .
Old Jun 5, 2025 | 11:19 AM
Desert Rider's Avatar
Desert Rider
Will the TS-136 work on the newer LT1/LT4?
Old Jun 5, 2025 | 12:04 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
A REALLY GOOD place to start is to purchase the 82 corvette GM service manual. It's worth its weight in gold. Look at eBay.
To please help with 82 crossfire
