Help with starter code
Old Jun 19, 2010 | 10:07 PM
69Bulldog's Avatar
69Bulldog
Default Help with starter code
I just took out my starter to have it rebuilt and it looks like it is not the original starter and I dont wont to pay big $ to get this starter rebuilt if its not a matching code for my car. I have a 69 SB 4-speed and the code is 1108325 7 F22. If I read this correct it is for a 1967 or 1977 made on June 22nd? Is this correct?
Jeremey
Old Jun 20, 2010 | 09:26 PM
Ironcross's Avatar
Ironcross
67`s and 77`s normally do not use the same starter because the nose determines the engine it would belong on, not its serial number..It would be extremely rare to have an original starter on a 40+ year old car, Rebuilders take the cores apart and the pieces are cleaned by the dozen and not part number specific, The cases are almost the same through the years and only the nose determines what it fits. Therefore numbers stamped on the cases are of no importance to the rebuilders and relying on numbers is not any concern to them. Unless they are building a customers special R/R unit.......'rebuild and return' like we do
Old Jun 20, 2010 | 10:43 PM
Mike Ward's Avatar
Mike Ward
I can only find a few vague references to that particular number, it was originally for a low HP six cyl '67 International Scout or Rambler.
Not a correct number for a Corvette.
Old Jun 21, 2010 | 12:54 PM
69Bulldog's Avatar
69Bulldog
Sounds good to me.. Thanks
Old Jun 21, 2010 | 12:59 PM
69Bulldog's Avatar
69Bulldog
low HP 6 cyl and a V8 5.7L use the same starter? Maybe I should just buy a AC Delco GM replacement starter and not rebuild my current starter.
thanks for the info..
Old Jun 21, 2010 | 01:59 PM
Mike Ward's Avatar
Mike Ward
I didn't quite say that. The housing where the numbers are stamped started off life 43 years ago on a six cyl engine. It's probably been through a few mix and match rebuilders shops and gotten scrambled with other parts that make it functionally acceptable for your engine. Take it to your local rebuilder and have them fix it- or do it yourself, not that difficult.
Old Jun 21, 2010 | 06:11 PM
Ironcross's Avatar
Ironcross
Exchange it for a HD 350 Chevy starter at a local parts store. If other replies are correct you have a LD 6 cylinder case with the appropriate nose to make it fit your Chevy engine. The HD case is a better overall starter for any Vette.
HD = heavy duty case
LD = light duty case
Old Jun 21, 2010 | 08:35 PM
69Bulldog's Avatar
69Bulldog
Below is my starter that I took out(I hope the pics are attached). Is a HD starter larger than the one in the picture? This starter must weigh 15-20lbs.. Also if you can see the gear in the nose section, I have bigger issues. Is this from not being shimmed correctly? I did not see any shims when I removed it. Thanks again..
Old Jun 21, 2010 | 09:06 PM
Ironcross's Avatar
Ironcross
The starter pictured with a cast iron nose is normally used on BB 396/427`s. I have never known of that starter successfully used on a SB. And yes, its a HD case.....That was determined on your side view picture showing the 3/4' distance between the switch and brass field terminal coming out of the case. A LD case would 'not have that 3/4' space between the switch. This is true with all the Delco starters.
99% of GM starters do not need shims and some rebuilders keep adding them in the boxes and contributing to the confusion....and I suspect if your having starter drive problems it just might be the wrong application. SB starters use aluminum noses either straight across on early engines and a staggered nose for late models.
footnote for you, is that your starter can by merely changing the nose fit your engine
Old Jun 22, 2010 | 11:38 AM
69Bulldog's Avatar
69Bulldog
I have a late production 69 car so I guess I need to find a staggered nose for this starter. Do you know where I can buy one of these? Should the shop that is going to rebuild my starter have these? Or another option is to buy a Delco remanufactured starter for $75.
thanks again for all your help..
Old Jun 22, 2010 | 11:51 AM
Mike Ward's Avatar
Mike Ward
If you mean that your car has a 3970010 block (late '69), there's only about 20 megagazillion starters out there with the correct nose and config- the most common design GM ever came up with.
Old Jun 22, 2010 | 04:02 PM
69Bulldog's Avatar
69Bulldog
I have not checked my block casting number before so I will need to start there first to make sure I get the correct starter.
According to corvette-world.com there are 3 block casting numbers for small blocks in 1969. Early, mid, and late 1969
Casting # Cubic Inches Description/Application
3932386 350 300 & 350 Horsepower (early)
3932388 350 (unverified)
3956618 350 300 & 350 Horsepower (mid)
3970010 350 300 & 350 Horsepower (late)
3935439 427 390, 400, 430 & 435 Horsepower (early)
3955270 427 390, 400, 430 & 435 Horsepower (early)
3963512 427 390, 400, 430 & 435 Horsepower (late)
3946052 427 430 Horsepower ZL1 (aluminum)
Old Jun 23, 2010 | 01:47 PM
69Bulldog's Avatar
69Bulldog
Mike, I checked by block last night and it is late 69 casting # 3970010 with a build date of Oct 6th 1969. This is the same block used in 1970.
I am now trying to locate a part # for this starter that I need but it seems like every website I look at there are two different starters that will work for my car. For instance, if you look at
http://www.corvetteamerica.com/cf/di...d%3A%20starter
you will see part# 33649 and part#36528 both can be used for a late69 or 1970 SB 4-speed. Am I missing something?
Thanks for you help..
Old Jun 23, 2010 | 02:34 PM
Mike Ward's Avatar
Mike Ward
I can't imagine going to the expense and trouble of ordering a starter via the internet, especially when a website gives confusing, incorrect and contradictory info. I honestly would not know which one to order from that site.
Go to your local auto parts store and get them to order a rebuilt. When it comes in, compare the two side-by-side and if acceptable, give them your old one as a core.
Old Jun 23, 2010 | 07:58 PM
Ironcross's Avatar
Ironcross
You need an aluminum nose staggered bolt hole HD starter. It fits all 350`s until they went metric around 1978-80. and then the shape was the same except they have metric threads and a short switch plus they lack the 'R terminal...The early 350 starter is available at any parts store...
Old Jun 23, 2010 | 08:17 PM
69Bulldog's Avatar
69Bulldog
Ironcross,
I just got off the phone with Shucks and they have a AC Delco rebuilt starter on the shelf with a cast iron nose. He said this is the replacement for my year. I even told him it was for a 1970 SB with a 4-speed. THis is the 2nd parts store that told me this. I cant believe this is that difficult..
Old Jun 23, 2010 | 08:49 PM
Mike Ward's Avatar
Mike Ward
It's not difficult.
Old Jun 23, 2010 | 08:57 PM
69Bulldog's Avatar
69Bulldog
The reason I said it was difficult is because Ironcross is telling me that I need a aluminum nose on the starter to be correct for my application but the old starter I took off the car and the starters at two different parts store are cast iron.
To Help with starter code
