engine pull
Old Jun 20, 2010 | 04:17 PM
jmp's Avatar
jmp
Default engine pull
Hi guys. I need to remove my engine from my 71' cpe. Whats the best thing to attach the chain to. I'll be using my lift to pull it. I've seen those brackets that attac to the intake manifold where the carb goes, but its an aluminum intake, and I'm not crazy about the idea of it holding the weight of the engine. Any ideas? Thank oyu.
Old Jun 20, 2010 | 04:20 PM
Skip Burney's Avatar
Skip Burney
use 2 long bolts in the intake manifold at each corner left front right rear and use big washers to make sure the chain can`t pull out
Old Jun 20, 2010 | 05:04 PM
mydejavooo's Avatar
mydejavooo
I used one long bolt on the left front side of the driver's side head, and one at the right rear of the passenger head, in between the engine and firewall. Worked like a charm! Just go slow and take your time.
Deja
Old Jun 20, 2010 | 08:57 PM
blue427's Avatar
blue427
borrow,rent, or buy an engine leveler to attach to your hoist.It's helpful especially for a bb and tranny pull at same time.
Old Jul 8, 2010 | 01:21 AM
C3Vettes.net's Avatar
C3Vettes.net
Get a leveler!!! Makes it so easy.
Old Jul 10, 2010 | 11:33 PM
AtHomeSoda's Avatar
AtHomeSoda
You can change the angle, and that is important...
Old Jul 12, 2010 | 12:16 AM
Rebelrob's Avatar
Rebelrob
I had the same opinion on the intake lift plate, but I have talked to several folks that are using these with no issues. Just use grade 8 bolts at least one inch and nice thick washers if you prefer. The center loop makes it easy for balancing. I have also used the each corner of the intake method, its a little tuff to balance it. I noticed that my stock engine has the original steel hooks already installed.
http://www.thefind.com/cars/info-engine-lift-plate
Old Jul 12, 2010 | 12:56 AM
Corvettetodd's Avatar
Corvettetodd
I used 3/8 inch grade 8 bolts bolted to the heads and an engine leveler when I pulled the engine on my 71. I dont see how I could not have done it without the load leveler.
Old Jul 12, 2010 | 10:00 AM
eastltd's Avatar
eastltd
I used the intake lift plate and it worked well.
Old Jul 12, 2010 | 11:05 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
You didn't mention if the tranny was coming out with it, but if so leveler 100%.
To engine pull
