Trim Tag Upper Number
Old Jun 20, 2010 | 09:51 PM
Jerapais 69's Avatar
Jerapais 69
Default Trim Tag Upper Number
Anyone out there know what the number next to "Chevrolet" on the trim tag represents? Saw one for example on ebay that said: "F27". I realize the two numbers below represent the original paint color as well as the material and color of the interior respectively. Confused on the upper number.....THANKS
Old Jun 20, 2010 | 10:18 PM
vettebuyer6369's Avatar
vettebuyer6369
Its the body build date. F27 is likely January 27th.
Old Jun 20, 2010 | 10:33 PM
Mike Ward's Avatar
Mike Ward
'A' is the first month of the production (not calendar) year so 'F' would be the sixth. Depending on what year car, that could be January to June.
27 is the 27th day of the month.
Old Jun 20, 2010 | 10:53 PM
Jerapais 69
Thanks boys. 1969 was the vette I was looking at.
Old Jun 21, 2010 | 01:55 AM
vettebuyer6369
Mike, my NCRS Guide says trim tag body build date month letter F = January in 1968 and 1969.
This date can be cross-referenced/verified by comparing it to your VIN assembly date.
Old Jun 21, 2010 | 05:54 AM
Jerapais 69
Where can I find VIN assembly date?
Old Jun 21, 2010 | 08:04 AM
GREGG-73's Avatar
GREGG-73
The Vin # ending for a 69 built in Jan., 1969 is 194379S714695. Your Vin # should be very close to this number. You can check your title for the Vin #. As for the motor....you can check the front pad of the block on the passenger side. You will find the last numbers of your Vin plus a suffix code. The suffix code will tell you HP and displacement.
Need more info to decode complete.
Stay in tune....
Old Jun 21, 2010 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
1969 model year production began in August, 1968, the week of the 23rd. August would be A; F should be January, 1969. F27 would be January 27th, 1969.
The time/build code indicates the day of the month the car passed the station on the assembly line where the trim tag was attached. For '69s, the body would have been assembled, painted, added to the assembly line. and partial assembly would have begun before the trim tag was attached to the body.
The car was probably not completed on the date on the tag, and is likely to have required another working day or day and a half to have been finished. January 27th, 1969 was a Monday. I'm guessing the car was completed late Tuesday or first thing Wednesday morning of that week.
Old Jun 21, 2010 | 09:43 AM
Mike Ward's Avatar
Mike Ward
Yes, that's true. The OP did not mention initially which year of car he was looking at though. Not all C3s started production in August. Some were September, some October. 1970 started production in January, making F=June.
To Trim Tag Upper Number
