79 to 80 bumper
Old Jun 21, 2010 | 03:21 PM
GS023's Avatar
GS023
Default 79 to 80 bumper
Looking to install a 80-82 style rear bumper on a 79. Anyone tried one of these.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={951f2de5-1353-4845-a49d-c4de2cd13fec}&gid={f0ed7a4c-7647-4643-88b3-fb08e81b1525}&GroupName=Bumper+Cover+%26 +Retainer&pname=80-82+TRUFLEX+Rear+Bumper+Cover&Referer=&Al ias=&ptct=SGR-SR&CTitle=&
Is it a bolt on or does it require any fitting?
Suggestions welcome.
Old Jun 22, 2010 | 11:27 AM
RaymondD's Avatar
RaymondD
I put the 80 rear bumper on my 77 with no problems. I did have to remove a couple of parts to make it fit. I'm not sure of the name of them but are 'V' shaped with a rubber strip on them, probably for keeping the bumper in proper shape. Also had to drill 1 bolt hole to hold the bottom of bumper to cross member. I used 80 rear lights as I couldn't figure out how to use the originals but I have seen them used on other cars.
Old Jun 22, 2010 | 11:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by GS023
...Is it a bolt on or does it require any fitting?...Suggestions welcome....
Call ZIP. They should be able to tell you what you'll need for the swap.
To 79 to 80 bumper
