1970 LT1 Ignition
Old Jun 22, 2010 | 01:38 PM
weisguy's Avatar
weisguy
Cruising
Default 1970 LT1 Ignition
I am switching my 1970 lt1 to the ignition system it originally came with. The problem is location of box and harness. I did find three holes that match in left front fender well but the box would be completly out of sight. Can anyone help?
Old Jun 22, 2010 | 02:59 PM
Brooklinite's Avatar
Brooklinite
Does this picture help? You should be able to see the box if you've found the right holes.
Old Jun 22, 2010 | 03:41 PM
...Roger...'s Avatar
...Roger...
The boxes are easy to find,do you need the dist also ?
http://cgi.ebay.com/ebaymotors/68-69...Q5fAccessories
Old Jun 23, 2010 | 01:29 AM
mstanton's Avatar
mstanton
Actual location varies slightly from car to car. Some are easy to see others are not. If you found three holes that's probably the original location.
To 1970 LT1 Ignition
