1976 Paint
Old Jun 24, 2010 | 08:43 AM
hwkaie's Avatar
hwkaie
3rd Gear
Default 1976 Paint
Hey, I have a 1976 Vette and have been trying to find the original paint color. The body plate located in the cowl is in bad shape and can not be read. Is there any other way to determine the original paint color of the car. I found another data plate located in the door jam that says "paint" and "trim" on it but i can't match anything on it with any of the paint codes.
Also, when i removed the seats i found another data plate underneath connected to the frame. Does anyone know what this plate is and what information is on it?
Old Jun 24, 2010 | 12:15 PM
garage-ghost's Avatar
garage-ghost
Pictures sure would help.
Old Jun 29, 2010 | 12:25 PM
richsteele's Avatar
richsteele
For the door jamb plate, here are the codes for paint and trim.
Paint Codes:
10 = Classic White
13 = Silver
22 = Bright Blue
33 = Dark Green
37 = Mahogany
56 = Bright Yellow
64 = Buckskin
69 = Dark Brown
70 = Orange Flame
72 = Red
Trim Codes:
Color Vinyl Upholstery Leather Upholstery
Black 19V 192
Firethorn 71V 712
Buckskin 64V 642
White 15V 112
Smoked Gray 152
Dark Brown 692
Blue-Green 322
Old Jun 29, 2010 | 12:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by hwkaie
...The body plate located in the cowl is in bad shape and can not be read....
There isn't a "body plate" on the cowl. Post a pic of what you've found.
...I found another data plate located in the door jam that says "paint" and "trim" on it but i can't match anything on it with any of the paint codes...
That's the trim tag and that's what you want. Post the codes for paint and trim; the time/build date of your 76 is in the upper right hand corner of the tag. You will find a letter and two numbers for month and day of the month. 1976 model year production began in August, 1975. August 1975 is A; September was B, etc.
...when i removed the seats i found another data plate underneath connected to the frame. Does anyone know what this plate is and what information is on it?...
There is no data plate on a Corvette frame and you should not be able to see the frame with the seats out. Post a pic.
Old Jun 29, 2010 | 03:57 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Ed T
well, uh, most of the time..
Yikes. Flintstone Mobile.
Old Jun 30, 2010 | 08:01 AM
hwkaie's Avatar
hwkaie
3rd Gear
Thanks for the help, I'll get those numbers off the trim tag and post them next chance I get. I tried matching them up with the information paint and trim codes richsteele posted above already but nothing matched up.
As for the data plate I found it was on the seat's frame (not the car frame). Sorry I worded that poorly. I'll take a picture of that and post it as well.
As for the body number plate located on the cowl, I read about that on this website:
http://100megsfree4.com/corvette/1970/vet76.htm
It mentions it right below the section about the different engine options. When i looked at the cowl there appears to be a plate bolted on in the location they mentioned however I can't read anything off it.
Old Jun 30, 2010 | 09:35 AM
Easy Mike's Avatar
Easy Mike
...As for the data plate I found it was on the seat's frame (not the car frame)....
Yep. It's a manufacturer's tag and it'll have a date code on it.
Old Jul 13, 2010 | 08:45 AM
hwkaie's Avatar
hwkaie
3rd Gear
Thanks for all the help, finally figured it out, turns out the car was originally classic white.
To 1976 Paint
