Aftermarket AC question...
Old Jun 25, 2010 | 12:31 AM
The13Bats's Avatar
The13Bats
Default Aftermarket AC question...
Do all the so called kits require that cars that did not come with factory AC loose that "CORVETTE" up in the top of the center gauges,
I dig the way that script looks in the dash but must add AC and soon....
Old Jun 25, 2010 | 02:09 AM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
It becomes an additional vent. But you could leave in the script and just let the supply lines vent towards the floor. The way the after market lines crush getting to that vent makes the vent less than worthy anyway. All the cold air hits the cabin either way.
Old Jun 25, 2010 | 12:50 PM
SteveG75's Avatar
SteveG75
The script was not there on stock AC cars either.
Old Jun 25, 2010 | 01:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Do all the so called kits require that cars that did not come with factory AC loose that "CORVETTE" up in the top of the center gauges...
All? No. Vette or Corvette Fever, can't recall which, did an AC article a few months back with an add-on kit (Vintage Air I think, but don't quote me on that) which did not use the CORVETTE panel above the cluster.
Old Jun 25, 2010 | 09:56 PM
The13Bats's Avatar
The13Bats
Right...I was pointing out the script found only in non factory AC cars.
So do you guys think enough air flow would come from the...what I will call the floor vents to cool things...could perhaps the defroster vent be used for AC air?
I just think the center console looks too cool with the script there to remove it for vents if I do not have to
Old Jun 25, 2010 | 11:11 PM
3JsVette's Avatar
3JsVette
Wouldn't the cold air hitting the hot glass cause the bottom of the windshield to fog up?
Old Jun 26, 2010 | 01:52 AM
The13Bats's Avatar
The13Bats
I really didnt know if that would be an issue....
Old Jun 26, 2010 | 11:59 PM
1969RAY's Avatar
1969RAY
Vintage air has connections to the defrost vent on the dash. It also supplies warm air, dry if the A/C is on.
Old Jun 27, 2010 | 12:37 AM
noonie's Avatar
noonie
Use the a/c defrost to defog the winshield all the time down here when it 95 outside.
To Aftermarket AC question...
