Rear deck compartment change out
My question is what holds in the fiberboard w/carpet panels into the trim ring that goes around the doors?
I see screws that holds the frame to the deck, and the rod thru the hinges to hold the door trim to the frame so are the fiberboards just glued in?
I can order complete assembly that only requires a complete swap out but my carpet is still fine so no need to swap out those covered doors and to be a lot cheaper not buying the complete assembly but just a new frame and trim units.
