vacuum hose diagram
Old Jun 27, 2010 | 09:46 PM
79c3man's Avatar
79c3man
Default vacuum hose diagram
where would I find a diagram of the heater control vacuum lines on a 79 corvette .I have a tiny line coming thru the firewall and then going to the wiper arm area connecting to nothing
Old Jun 28, 2010 | 10:05 AM
78IndyPace's Avatar
78IndyPace
Send me a PM with your email address and I'll send you a .pdf file with a complete climate-vacuum diagram for a 77 Vette. It's the best diagram I've found so far. It works for my 78 and is likely the same for your 79, too.
Jerry
Old Jun 28, 2010 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your tiny line problably goes to the flapper door on the right hand side of the cowl. This door closes with vacuum when the AC is on. Opens for fresh air.
The assembly instruction manual (AIM) shows the flapper installation; the AC section shows the vacuum supply line.
The fender is off of this car, but you can see the flapper door and the valve.
Old Jun 28, 2010 | 12:25 PM
79c3man's Avatar
79c3man
yes thats the one ,thank you , but how the heck do I get to it to put the hose back on ?
Old Jun 28, 2010 | 03:22 PM
Easy Mike's Avatar
Easy Mike
There's a nipple on the front side (not shown in the pic). Remove the debris screen at the end of the wiper trough and you'll see it.
AIM shows it.
Old Jun 29, 2010 | 01:33 PM
elke_10's Avatar
elke_10
Default kinda th esame issue here
ok instead of posting a new thread on this hopefully it will get noticed. i need to know where the main vacuum for the hvac switch goes all i can seem to find is diagrams for cars with cruise control my vette don't have cruise and before my switch didn'twork so i wire the canisters open to get air. well after a good bit of redoing i found the main line folded and tucked away on top of the dash. so now where does it go to get the vacuum it needs?
Old Jun 29, 2010 | 01:39 PM
Easy Mike's Avatar
Easy Mike
elke: Check the assembly instruction manual (AIM) for your year under the AC section.
If memory serves, you will find a T off the main (headlight) vacuum line in the area of the rear of the left head.
Old Jun 29, 2010 | 02:06 PM
elke_10's Avatar
elke_10
thanks mike there is a tee a lil ways from the check valves on the main headlight vacuum hose but its been plugged off. but it seems to be a large tee nothing that would fit the lil hard vacuum line. as for the manual is there anywhere i can find that without buying one. don't really see the need to spend 30 bucks for this. since this is the only thing i can't figure out lol
Old Jun 29, 2010 | 03:27 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by elke_10
...don't really see the need to spend 30 bucks for this. since this is the only thing i can't figure out...
Trust me. AIMs are worth their cost. Ditto for the chassis service manual.
Old Jun 29, 2010 | 04:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You'll find a colored diagram at this link. http://willcoxcorvette.com/repairand...lp.php?hID=273
You will also find on that link one to the AIM on CD.
Willcox
Old Jun 30, 2010 | 11:43 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Willcox Corvette
79..
Willcox
Good stuff.
Old Jul 4, 2010 | 08:56 AM
0Willcox Corvette
Former Vendor
Thanks Mike,
I'm working on a better one with actual hoses, relay's and parts and thinking about a video on how to test.
To vacuum hose diagram
