Engine Weight?
Old Jun 30, 2010 | 12:29 PM
bence13_33's Avatar
bence13_33
Default Engine Weight?
Does anyone happen to know how close the weight of a BBC motor with an iron block, aluminum heads, aluminum intake and aluminum water pump is to an all cast iron SBC motor?
For some reason I remember thinking that the BBC with aluminum parts was only 100 or so lbs heavier than the iron SBC but it's been a while. Any help is appreciated!
Old Jun 30, 2010 | 02:50 PM
mysixtynine's Avatar
mysixtynine
The older iron headed motors were about as follows
sbc=575 lbs
bbc=680 lbs
Going aluminum on a bbc for heads and intake gets you right into small block iron headed weight.
The new engines seem even lighter. http://www.gmperformanceparts.com/_r...talog_2010.pdf
page 10 shows the deluxe iron headed vortec 350 at 481 lbs and the deluxe aluminum headed zz502 at 611 lbs.
Old Jun 30, 2010 | 02:56 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Figure on about 620#. With mini-starter you can subtract ~10.
FYI, that's only ~100# more than an iron SB w/alum intake (L82 ~525#), despite the widely held notion that BB's weigh as much as supermassive blackholes.
Old Jul 1, 2010 | 11:15 AM
early shark's Avatar
early shark
I can tell you that the factory stock 1971 LS6 engine weighs 60lbs more than a '69 L46 engine.
Old Jul 1, 2010 | 12:35 PM
bence13_33's Avatar
bence13_33
I guess that's not too bad, roughly I guess my motor is around 610lbs (mini starter). I can't remember for certain but I thought I remembered shaving 80lbs off my BBC when I switched from cast iron to aluminum heads.
So basically my BBC is only about 45lbs heavier than my original all cast iron SBC. I also have an aluminum radiator which was noticeably lighter than the original unit. Thanks for the help guys!
Old Jul 1, 2010 | 12:42 PM
TheSkunkWorks
I've typically heard they're worth about 75# for the pair, and my aluminum heads weighed in at just a touch under that lighter than the iron ones they're replacing, both sets complete with rectangle ports.
Old Jul 2, 2010 | 09:24 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I got some very similar numbers on my engine. Pulled the engine out today, and put it on my (semi-antique) digital hanging scale. The engine is complete other than the headers and air filter housing. (Lightweight L-88 flywheel/clutch system, late C4 starter, and aluminum heads and water pump.)
Got everything hanging from a load cell for the scale. (I zero'd out the weight of the chains and leveler.)
And the reading I got:
Old Jul 3, 2010 | 07:35 PM
TheSkunkWorks
Now let's see that ZL1 based mill on the scale.
Old Jul 3, 2010 | 08:03 PM
69427's Avatar
69427
I'm transferring several parts from this engine (pumps, intake, heads and cam, etc) onto the new shortblock, and I'll be more than a bit disappointed if the scale doesn't notice much difference.
I'll post another reading once I get it put together.
To Engine Weight?
