Modernizing a C3?
So, I no longer own my 1979 L82, or my 1996 Collectors Edition. I am, for the moment, Corvette-less, and stuck in SUV land. Its a dark, and dismal existance.
I want a C3 I can drive, not daily, but at least 2-3 times a week, on weekends, and at an occasional autocross and perhaps yearly track day.
Facts:
* My wife and I love the late C3s, and WILL buy another.
* I HATE H8 HATE!!! carburators, and trying to maintain street legal vehicles with miles of rotting rubber vaccume hoses.
* I have built triple-threat cars before (street, autocross, track) by myself including a 1979 L82, a 1996 CE LT4, a 1993 Miata, a 1996 Honda Del Sol, and a 1979 RX7.
Questions:
How much custom fab would be required?
What other considerations such as weight distrubution, driveability, fit and finish do I need to think about?
Got any articles, experiences, know anyone who has done it?
Thanks in advance brothers.
Facts:
Questions:
Rick B.
FrankenSport Build
I've toyed with the idea of selling mine. I took it to work three days last week and enjoy it but other priorities have surfaced.
PM me if interested. If not, I would still be happy to answer any specific questions.
Joe..
Check out Street Shop's frame & engine options. Have seen their work, its "modernized" where it counts.
http://www.streetshopinc.com/
StreetShop (your neighbor) makes a great chassis and you can bolt in C4 suspension and an LS6/A4 or 6spd Drivetrain.
To address some of the OP questions:
Questions:
Depending on route you go, anywhere from none to major. You can modify your chassis to accept C4 or go with something like the StreetShop chassis and require no modifications. The SRIII Chassis and some others require a mod to the rear storage area.
If you can consider things like Brake lines, Fuel System, and some electronics custom fab, then an aftermarket chassis will require some level. Any LS engine will require a Fuel System upgrade to an Electric EFI pump pushing about 58psi. There are companies such as RockValley that will sell you a drop in tank or many here such as Rick - 72LS1Vette - did a great job modding their own fuel system.
What other considerations such as weight distribution, driveability, fit and finish do I need to think about?
IMO Depends on what you what the end result to be. If you use aluminum suspension components, coilover shocks, aluminum rear and halfshafts, aluminum driveshaft, etc. etc. you can lighten it a lot. Mine fully loaded is 3120 with a tank of gas and the SRIII chassis is a little heavier then stock.
As far as driveability goes depending on how you set it up it can be fully adjustable. With adjustable coilover shocks and changing sway bars you can tailor the ride to anyway you like it.
There are many threads here (as well as the sticky at the top of the C3 Tech as mentioned) about members who have done conversions or just turned their little C3 into their own beast. So it really comes down to what you want the end result to be and how much you want to spend to get there.
Joe..
That car is truly one of the nicest cars on all of Corvette Forum. But......
Just finishing a "frame off" on a 67 MGB I couldn't bring myself to spend the time and coin to do a restomod like that, nor could I afford to pay someone to do it for me.
To the OP - take your wife to drive a C6. You'll be surprised at the performace, comfort, and roominess in it. No vacuum system to maintain either.
Just saying..........
). If you build something as nice as Joe's car you will spend over 100K unless you do a lot of work yourself. Plus there is the time factor involved with doing something like that. If you buy a "nice" car and convert it you can do it in stages and limit some of the down time. Depending on what you want to spend for a motor and whether or not you want to buy a frame I'm guessing you could build a very nice car that's lots of fun to drive for somewhere in the upper 20Ks to low 40Ks. By all means if money is no object build yourself a car like Joe's but you can still have a lot of fun on a smaller budget if you are realistic with your expectations and abilities if you spend your money wisely. Good luck with what ever you decide.
Interior shot (not quite done)...
Don't look if you don't like carbs...
Shouldn't cost more than an average driver quality resto when finished and stock C4/5/6's shouldn't run away from it either.
My time has vanished. My car still is not done. I am building Davids motor right now and that has to be done before July 16th which will be no problem. I have another car to do some work on next week and another one after that. Nothing to much but it still takes time. I have had no time on weekends at all. Happy to help but summer is a tough time.
I'm planning on tearing down my '78 to the frame and building it back up with more modern parts at my next base. Hoping to start next year sometime with a chunk of my reenlistment bonus.
I've had a SRIII frame with C5 suspension rolling around in my head all week to be honest. Considering purchasing one of the 408 strokers from T&L but I'm as of yet undecided if I want to stick with a carb or not.
My end goal is to have the sexiest car within 500 miles that I can drive daily if I want.
I've build and driven pretty much all available bolt on upgrade suspension set ups available for C3's. (Stock, coil overs in all corners, heavy springs, different sway bars, composite mono leaf set ups and even the guldstrand 5-link with coil overs) I have pretty good idea of what a good suspension should be like. Even though couple of my cars ride really well and handle good that are far from modern C6 type ride.
Next big project I will do will start with a Street Shop C6 chassis and that way I can use C6 Z06 drivetrain, brakes and suspension and there's plenty of good upgrades available for those too.
Starting with a C6 suspension will give you the most modern feel GM has to offer. It'll require a lot of floor surgery, but once it's there you still end up with a stock looking body from the out side, so it's a good for a sleeper style build too.
Once you have you chassis/suspension/brakes sorted. Just find a suitable LSX power plant and you are on the right path. Adding the just released LS9 supercharger kit on a LS3 will be a great motor with 650hp.
As for body, keep it stock appearing yet loose as much weight as reasonably possible, yet add some dynamat to keep the noise levels down. Forget traditional side pipes and add trick butterfly valved full exhaust, so you'll keep the car very quiet on low rpm's and all hell will break loose when you step on it.
Vintage Air AC kit and some discreet stereo will make sure your cockpit will always be a pleasant place to be. Get LED tail lights and HID's for the front with electric motor conversion.
And and and and...
