I am getting my engine gone through and found two different head numbers. It is a matching number block and has the correct intake and card, but one head is a 3998993 and the other is a 3973487X. According to my books, they should both be 3973487. I get all kinds of info from different sites for '72 LT-1's. Any info from the experts here?
I'm no expert, but my NCRS Specifications Guide lists the 487 heads for the 72 LT-1s. The 993 heads are shown for the 200hp base engine but unverified and for 73 and later L-48s.
Same info I have. 72 LT-1 should have 487X. My '71 L48 original engine has 487 (non-X) factory heads on it.
The NCRS guide states that the X shows up on later 1972 3973487 base and LT1 cylinder heads. I have 2 LT1's and they both have the 3973487(X) heads and one was built in March and the other one in June of 1972. I hope this helps.
