Removing outside door handle
Old Jul 12, 2010 | 09:30 PM
elecriciandude's Avatar
elecriciandude
Default Removing outside door handle
Okay, I've done t/a's, dash's, u-joints,yada yada, how do you remove the door handles. I know the linkage has to come off the lever,so someone splain it for me. thanks,Terry
Old Jul 12, 2010 | 09:35 PM
Leung's Avatar
Leung
Take the door panels off. Remove the lock rod connected to the handle. Theres a clip holding the rod onto the door latch mechanism. Then remove the two bolts holding the handle in. Good Luck.
Oh yeah, hopefully you have some small hands as theres almost no room to work with.
Old Jul 12, 2010 | 09:37 PM
bluthundr's Avatar
bluthundr
Check out http://www.corvettefever.com/howto/4696/photo_01.html
Old Jul 12, 2010 | 09:40 PM
elecriciandude
I was afraid you were going to say the clip word. Is it the style of clip that some carb linkage connects with?
Old Jul 12, 2010 | 09:41 PM
Leung's Avatar
Leung
There's one pictured in bluthundr's link.
Old Jul 12, 2010 | 09:47 PM
elecriciandude
Thanks Guys,a picture is worth a kazillion words,Terry
Skip Burney's Avatar
Skip Burney
You are gonna need a 1/4 inch drive ratchet, 2 extensions and 2 universals. I forget what size socket you need.
Old Jul 12, 2010 | 10:36 PM
71406's Avatar
71406
Its a much easier job if you remove the door latch.
To Removing outside door handle
