DRIVER SIDE HINGES sagging
Old Jul 15, 2010 | 11:24 AM
phildawg19's Avatar
phildawg19
Default DRIVER SIDE HINGES sagging
I was wondering if anyone had any instructions as to how you install new driver side hinges. Im going to try to attempt and get this done this weekend so i was wondering if any of you could guide me on the right path? thanks!
Old Jul 15, 2010 | 11:55 PM
68/70Vette's Avatar
68/70Vette
Sorry, it seems a little straight forward. For the door, there's a little steel panel adjacent to the hinge you have to remove do undo the door side fasteners. For the body, you have to remove the driver's side kick panel and then you can get to the body side of the fasteners. The side kick panels can be a little balky to get loose. Pull the carpet that sticks up under them,....out. Also, loosen the driver's side speedo/tach panel screws a little bit to give you some slack to get the kick panel out.
The door is pretty heavy so getting it loose means you have to plan to have something to support it after you remove a hinge. If you don't mind spending the money, Eastwood sells door supports with dolleys that will hold the door when you remove a hinge.
Finally..DO YOU HAVE NEW HINGES? Where did you get them, I'm been looking for some. (There are hinge rebuild kits available which provide for re-bushing the hinge spring holes.)
Old Jul 16, 2010 | 11:46 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Best buy urself a Shop Manual first. It's not a "simple" job but can be done by a novice (even me). You'll need a buddy to help hold the door,or a jack as mentioned above. Removing the dash panel is what has stopped me this far
Old Jul 16, 2010 | 12:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mikejpss
...Best buy urself a Shop Manual first...
or the assembly instruction manual (AIM). Upper hinge bolts on the interior will be a little hard to hit with the dash pad in place.
Are you sure you need hinges and not hinge pins and bushings?
Index the hinge bolts (door and door post) and the shim stacks before you remove them. You want to use the factory locations and shim stacks as a place to start for door fitting if you install new hinges.
Old Jul 16, 2010 | 04:45 PM
killain's Avatar
killain
Oldtimer
Thee was/is a rebuild kit for this problem. It has two brass pivots bushings and two new hinge pins. A lot cheaper that replacing the whole hinges. I've seen the at Pepboys sold under the 'Help' brand also calls the motormite brand in a red container.
Motormite Mfg Div
P.O. box 1800
Colmar, PA 18915-1800
Old Jul 16, 2010 | 04:56 PM
phildawg19's Avatar
phildawg19
My dad and i know a guy that has had a family corvette sales/restoration shop for a long time. I did some work for him and I just told him I'd take the hinges for compensation. It worked out and they were new in box. Not sure where they came from though Ill check with him and get back to you on it. He said new hinges upper and lower for one door was about 260 bucks retail.
Old Jul 16, 2010 | 04:57 PM
kaiserbud's Avatar
kaiserbud
don't forget the 'S' spring while you are at it.... I need to do this and dread it.
phildawg19's Avatar
phildawg19
but i might just try doing the rebuild kit. just to see if that would work and if it works ill sell the new hinges
Old Jul 16, 2010 | 06:45 PM
jimo's Avatar
jimo
i had done some repair work on my drivers side door hinge, but i was lucky that i already had the dash out, so it made the job a little easier.
Old Jul 16, 2010 | 07:07 PM
hammadown's Avatar
hammadown
You don't have to pull the dash out to change hinges
if anything you have to loosen the two screws on each side to give you a little slack to remove the lower kick panels
Hammadown
Old Jul 17, 2010 | 02:20 PM
phildawg19's Avatar
phildawg19
you dont?? well awesome i guess i havent really gotten up in there yet to see. Im going to try the repar kit first, but does anyone know where i can get them to fit our cars? i went to o reilly yesterday and auto zone but the pins were about and inch and half too long
Old Jul 17, 2010 | 10:13 PM
mikejpss's Avatar
mikejpss
Hammadown
You must not be talking about an 80 or 81 model. On those models you can NOT hit the top hinge bolts without removing the dash on the drivers side. ask me how i know this. if you know differently, PLEASE speak up. thanks. mj.
Old Jul 17, 2010 | 10:16 PM
mikejpss's Avatar
mikejpss
the "S" spring changeout on an 80/81 model is childs play. all that is needed is a flat screwdriver about 12-14 inches long, bend a 30 degree angle in the shaft about 4 inches back from the tip. check out a few vendors website for the tool ,they sell for $10-12, or buy a cheapie screwdriver and bend urself. easy job, really.
Old Jul 20, 2010 | 07:02 PM
mickey67vet's Avatar
mickey67vet
It is better to rebuild your own door hinges and use a kit, fairly simple to rebuild. If you buy new or rebuilt be careful as the hinges changed in the 70 model year. I have a 69 and I bought a set that I could rebuild (these were 70/76), when I tried to put the door on the door pockets that enclose the hinges they would not fit. The later year hinges have more meat on them because the doors got heavier with all the power options,locks windows etc.
Old Jul 21, 2010 | 11:54 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by phildawg19
...you dont??...
There's where you're going. The dash is out of this car making things much, much easier to see. It'll be dark up there. Crawl under the dash and take a look in that direction.
You can get to the lower hinge behind the kick panel.
Good luck.
Old Jul 21, 2010 | 12:52 PM
phildawg19's Avatar
phildawg19
thanks for the help. i just ordered the repair kit for the hinges off of ecklers for about 20 bucks amd new springs so im going to give this a try first to see if the door will meet flush and if not then ill put in the new ones
To DRIVER SIDE HINGES sagging
