Upper Radiator Hose???
Old Jul 17, 2010 | 10:59 PM
JED77Vet's Avatar
JED77Vet
Cruising
Default Upper Radiator Hose???
Today I took my 1977 to an auto show, about a 70 mile ride in 90 deg. heat. When I got the car to the show, I popped the hood and after a 1/2 hour or so noticed that the upper hose had squeezed up, nearly flat. The car temp. had been 195 deg. the entire trip up, but I wonder if I would get home. After the show I drove it about 5 miles, stopped and checked and the hose was normal. Had lunch and drove home, no issues but when I parked it in the garage and popped the hood, noticed the same thing. Should these hoses have a wire coil for structural support? Anyone else see this happen? I bought the car this spring, not certain how old the hoses are. Temps home were normal as well.
Old Jul 17, 2010 | 11:08 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
a new hose is 25 bucks or so. a good way to give you piece of mind when you drive it
Old Jul 17, 2010 | 11:24 PM
noonie's Avatar
noonie
You either have an incorrect rad cap or the correct one has a stuck refill valve.
Old Jul 18, 2010 | 08:32 AM
Duke94's Avatar
Duke94
Buy a new cap. The lower hose has the spring inside the upper has none.
To Upper Radiator Hose???
