for a smart guy-
Old Jul 19, 2010 | 08:32 AM
jnb5101's Avatar
jnb5101
Default for a smart guy-
-i can pull some really dumb stunts! finally tried to fire the rebuilt engine in my 72 vert. i switched frames due to rot and just finished painting-no i didn't mess the paint up-not that dumb! the wiring harness isn't connected, so i used a remote start switch to crank it. it felt like it wanted to start, but wouldn't catch. played with the distributor clocking without any results. as a matter of fact it felt worse. sat down to think for a minute, and realized that i needed to put 12V on the coil, so that when i released the start switch the coil would be energized. wait for it-not yet! wired the coil and was just getting ready to try again and i leaned over the cowl to check the -this is it- the oil pressure gauge. what gauge? i forgot to hook-up the gauge. deep horizon here i come! luckily i had placed a small plastic bag over the end of the oil line so most of it was trapped. just touched the start switch and it fired!
Old Jul 19, 2010 | 09:59 AM
7t5's Avatar
7t5
St. Jude Donor '14
been there, done that. Except I forgot to put the oil filter on. It was a Grand Am where the oil filter hole pointed up, so I soaked the engine bay. Pure genius.
Old Jul 19, 2010 | 10:27 AM
BassCat's Avatar
BassCat
I replaced my fuel pump awhile back. Couldn't get it to start afterwards so I kept pumping the gas, thinking it's a new fuel pump, just needs more gas. Pumped and pumped and pumped-still nothing. Finally dawned on me that I had unplugged the hot wire going to the distrbutor earlier. Snapped that wire back on, turn the key and Kaboooom! Completely blew the right side muffler into pieces. It's a miracle it didn't go through the fiberglass. Wife still ribs me about that one. lol.
Old Jul 19, 2010 | 03:18 PM
BB72's Avatar
BB72
On my first vette I had a 406 bottom end built. The machine shop didn't put the oil plug on the head surface. I put the rest together and I fired it. It started up great aside from the litre of oil it shot all over the ceiling and walls of the garage. Never though to check.
Old Jul 19, 2010 | 03:27 PM
onaqwst's Avatar
onaqwst
i put the front calipers on the wrong sides...hence the zerk fitting was on the bottom and couldnt figure out why i wasnt getting a good pedal...
Old Jul 19, 2010 | 03:39 PM
phildawg19's Avatar
phildawg19
Bass i see your from thomastown. Im actually living in starkville right now. do you know of any get togethers coming up or anything?
Old Jul 19, 2010 | 03:58 PM
texaswilkins's Avatar
texaswilkins
I was changing the motor/trans and had it back in enough it should start. Spent several hours trying to figure out why it wouldn't fire when I bumped my shift linkage and it moved. Put the silly car in park and it fired right up.
Old Jul 19, 2010 | 07:28 PM
hammadown's Avatar
hammadown
Now ...........that right there is FUNNY........... I don't care who you are
Hammadown
To for a smart guy-
