Camshafts
Old Jul 21, 2010 | 12:49 PM
phildawg19's Avatar
phildawg19
Default Camshafts
Ok so i have come to the conclusion that i have a basic GM 350 motor that was put in the car about 5000 miles ago before we purchased it. Im not sure of the cam thats in it yet. whether its flat tappet as it was stock or if the PO placed a roller cam in. But in the case that it is still flat tappet, what kind of cam kit should i get? the best/best price.
Old Jul 21, 2010 | 01:32 PM
bashcraft's Avatar
bashcraft
What's the reason for changing it? This little bit of information can make a big difference.
Old Jul 21, 2010 | 01:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bashcraft
...What's the reason for changing it?...
Why not keep what you've got, drive the car for a while, then decide where you want to go with it?
Old Jul 21, 2010 | 03:17 PM
phildawg19's Avatar
phildawg19
just from looking around and hearing guys talk everyone suggests changing to roller cams. what is the purpose in it?
and also is it ok that im using 10w 30 oil in this? i have been taking a couple long trips so i have been changing the oil myself and placing this grade in there.
Old Jul 21, 2010 | 05:24 PM
Scott Marzahl's Avatar
Scott Marzahl
If its a flat tappet cam you should probably add some ZDDP additive to it for added insurance.
Old Jul 21, 2010 | 05:34 PM
Skip Burney's Avatar
Skip Burney
Changing a cam just for the sake of changing is not what I would do. Why would you want to do that. Cams need to be matched to heads, compression, valve size, combustion chamber size, rear end gear and a lot of other things. A lot of people think getting a bigger cam will make them faster or sound really cool and then don`t understand why the car runs like crap. Think about what you use the car for and then build an engine for that purpose. IF IT AINT BROKE DON`T FIX IT
Old Jul 21, 2010 | 07:52 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
If it is a flat tappet camshaft, you should run either ZDDP additive or oil that already has high zinc in it listed here : http://forums.corvetteforum.com/c3-t...ppet-oils.html
Will
Old Jul 22, 2010 | 11:32 AM
phildawg19's Avatar
phildawg19
i know they have to be matched im just wanting improved performance and especially more hp... im taking a wild guess right now that im pushing about 350 with this engine and the upgrades. im checking the cam tomorrow to see if im lucky and there is already a roller in place.
ok so with the oil.. once i check the cam and do find out it is a flat tappet. will this increase in zinc cause the car to perform better or is it just for the sake of engine life?
Old Jul 22, 2010 | 12:36 PM
Scott Marzahl
The zinc is ONLY to protect the cam from wear. You don't mention any upgrades but 350hp??
Old Jul 22, 2010 | 01:10 PM
SPD151's Avatar
SPD151
Default Cams
My 2 bits on this, I would not convert to a roller cam without some thought, as this can run into more changes than you might think. My first rebuild I stayed with a flat tappet cam and ended up with cam wear problems that resulted in a tear down of the engine. I went back with a roller cam the second go around and this was in a very expensive attempt to avoid any further cam issues. There do seem to be a growing group of people who believe that failures of flat tappet cams are of epidemic preportions. If not for the expense the build and then rebuild cost me, it is almost laughable to watch the big blame circle go around. The builders blame the cam company, the cam company blames the oil maker, the oil maker blames the people providing the cores for the cam company. Still before dropping alot of money in building a motor I would read up on it. I also see now that some of the cam people are selling their own brands of oil additives for breaking in flat tappet cams. Then still you have others that continue to use flat tappet cams and have not had any issues at all
Old Jul 22, 2010 | 02:15 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
And for the reasons stated above I use more custom cams now to properly tune an engine package for my needs.
Old Jul 22, 2010 | 02:58 PM
Skip Burney
[QUOTE=phildawg19;1574775847]i know they have to be matched im just wanting improved performance and especially more hp... im taking a wild guess right now that im pushing about 350 with this engine and the upgrades. im checking the cam tomorrow to see if im lucky and there is already a roller in place.
ok so with the oil.. once i check the cam and do find out it is a flat tappet. will this increase in zinc cause the car to perform better or is it just for the sake of engine life?[/QUOTE
I seriously doubt you have a roller, I have built both flat solid, flat hydraulic and rollers and have never had any cam problems. You didn`t tell us is the car an automatic or manual. a big cam will cause converter and vacum problems. What are you going to degree the cam at or are you just going to sitck it in and hope for the best. Degreeing a cam with the engine in the car is a hassle at best. Do you have a degree wheel and dial indicator to set it up with? I`m not trying to rain on your parade but it sounds like you are going to spend a bunch of money just to sound good at the drive in on Sat night and you may do all of that and be dissapointed with the results. You could put in a huge cam and then have small heads with a stock intake and not enough carb to feed it and end up with a dog.
Old Jul 23, 2010 | 10:30 PM
glen242's Avatar
glen242
"im taking a wild guess right now that im pushing about 350 with this engine and the upgrades."
Wild guess is correct! Unless you have upgrades that you are not mentioning.
Old Jul 24, 2010 | 06:29 PM
phildawg19's Avatar
phildawg19
i do. i just found out today i have diff heads, performer eps intake, 1406 carb, hooker headers and i know im missing a couple more things but oh well. ive decided im not worrying about my cam right now. it is flat tappet and i know now i need to add oil withhigher zinc levels. but right now shes running beautifully so i wont touch a thing
Old Jul 24, 2010 | 07:59 PM
Skip Burney
Like I said " If it ain`t broke don`t fix it"
To Camshafts
