Lacquer Painters, Need Help!
Old Jul 22, 2010 | 06:41 PM
CCrane65's Avatar
CCrane65
Default Lacquer Painters, Need Help!
A fellow forum member is in the process of painting his '70 convertible with Laguna Gray lacquer and running into heat related problems. The paint on the rear deck is streaking.
Does anyone have or know where he can get some drying retarder?
Please let me know if you do.
BTW, his forum id is $tingray.
cc
Old Jul 22, 2010 | 07:18 PM
Skip Burney's Avatar
Skip Burney
Why laquer?
Old Jul 22, 2010 | 07:20 PM
CCrane65's Avatar
CCrane65
Originally Posted by Skip Burney
Why laquer?
He's doing an NCRS correct restoration.
cc
Old Jul 22, 2010 | 08:06 PM
noonie's Avatar
noonie
Not sure what you mean by streaking, metallic not even or sheen not consistant, but here is the retarder. Any Dupont jobber should have it.
Most other manufacturers carry their own too.
DuPont™ 3979S™ Acrylic Lacquer Retarder
In a pinch some hardware stores carry it for wood cabinet finishing, but it is not as good a quality as the auto stuff.
Here is Porter Paint's a beter quality than hardware stores.
Porter Lacquer Retarder #863. They are now owned by PPG and have stores in most metro areas.
Sherwin Williams Automotive has it as Universal Retarder R7-K6251
Old Jul 22, 2010 | 08:15 PM
CCrane65's Avatar
CCrane65
Thanks noonie.
They way he described it to me is it looks like there are stripes on the rear deck. I am assuming they are the width of the spray pattern.
cc
He did also mention the metallic is not spread evenly.
Old Jul 22, 2010 | 08:25 PM
noonie's Avatar
noonie
Retarder is generally used for the sheen, to prevent orange peel, dry spray, and moisture entrapment from too much humidity.
Sound more like he has application, mixing, technique problems. Lots of practice for heavy metallics.
Retarder is strong, so be carefull about shrinkage etc.
Old Jul 22, 2010 | 08:28 PM
markids77's Avatar
markids77
Retarder might help. But streaking can also be addressed with both increased reduction (more thinner) and more fluid/less air at the tip so you achieve a wetter coat. A slower gun arc might help as well. I assume he is using the slowest thinner available from whoever is supplying the paint? Be careful... weather hot enough to interfere with paint flow often contains enough humidity to make "blush" a real possibility if you play with wetness/drying speed. It was 96 degrees here in Savannah today with humidity over 80 percent... I wouldn't want to try a lacquer job here right now even in a great booth!
Old Jul 22, 2010 | 09:09 PM
Skip Burney
I was in Savannah today and it was terrible, the humidity was like a wet blanket on you
Old Jul 22, 2010 | 09:48 PM
CCrane65's Avatar
CCrane65
It was around 100 today but only about 48% humidity here in Wichita.
cc
BTW, looks like we're stuck with low to mid 90s for the next week at least.
Old Jul 22, 2010 | 09:51 PM
markids77's Avatar
markids77
Yup... been like that all week, and probably next week as well. So far no thunderstorms right here to relieve the heat... probably in Brooklet tonight from the look/sound of things??? Hope so, we could all use the rain.
Old Jul 22, 2010 | 09:53 PM
markids77's Avatar
markids77
Ccrane... could the paint application wait a month or so? Life is easier, and the result will be better with more moderate temperatures... and the job will look that much nicer.
Old Jul 22, 2010 | 10:12 PM
CCrane65's Avatar
CCrane65
I really can't answer that. I know he has been waiting about 2 years to get it in for paint. Now it's almost done except the rear deck and the heat is cooking it. They have been working the same area for a couple of weeks now.
cc
Old Jul 22, 2010 | 10:24 PM
markids77's Avatar
markids77
If your friend is paying someone to do this job, and we're having this conversation there's an experience gap that needs addressing. I know that lacquer is a "fading" paint medium, but I'm not a fossil yet and it was common in my youth. I council a "stop and regroup" session with the owner and painter if the issue has not been resolved "for a couple weeks now". $tingray... what's the "real deal" on the paint for your car????
Old Jul 22, 2010 | 10:40 PM
CCrane65's Avatar
CCrane65
I don't think patience is an issue. He spent about 2 months getting the mixture right to match a 1970 color sample he has.
I think it's more a problem that the painter, who is a very good friend of ours is not well and his hands shake a lot these days. If I remember correctly he is 71. But he does beautiful work. It just takes him longer these days.
cc
Old Jul 23, 2010 | 12:20 AM
Frogday's Avatar
Frogday
cc
If he is doing an NCRS restoration on a 1970 it shouldn't be Steel Cities Gray, that was a 1971 and 1972 color. Would this be Laguna Gray? That was a 1970 color. (not that it makes a difference for the paint issue anyway)
Old Jul 23, 2010 | 08:37 AM
CCrane65's Avatar
CCrane65
Yeah, that's correct. I put the wrong color name in the post. Thanks for the correction.
I'll go back and fix it.
cc
Old Jul 23, 2010 | 11:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If it's as hot and humid where he is as it is here today, he does not want to be shooting lacquer.
To Lacquer Painters, Need Help!
Old Jul 23, 2010 | 12:04 PM
CCrane65's Avatar
CCrane65
Yeah, today we're looking at 99 and about 78% humidity.
Next week we drop to the low to mid 90's.
cc
Old Jul 25, 2010 | 01:09 AM
CCrane65's Avatar
CCrane65
The place that supplied his paint was able to locate the PPG/Porter Paints retarder and will have it to him Tuesday.
Thanks again noonie.
cc
Old Jul 25, 2010 | 04:03 AM
noonie's Avatar
noonie
At 71, something tells me he's got a lot of experience with this.
Should have no problems with the retarder, hope he used a real sealer over the primer. On a high metallic like a grey, the last coat can be thinned a little more, a little more distance with the gun and a lot more speed. Object is just to mist for the metalic uniformity.
Good luck.
