Brake Mystery ??
Old Jul 24, 2010 | 11:07 PM
68vetteman's Avatar
68vetteman
Default Brake Mystery ??
I changed my car from manual to power brakes with a chrome booster and master cylinder. The brake pedal was close to the floor and I thought this was normal for power brakes. I never had a problem stopping. Last time out the brake light came on, got home and I stood on the brake pedal. If a line or hose was blown there should be a puddle in the garage, nothing. Removed the master cylinder cover, fluid clean and full. I removed the M/C and took it apart. There was grit like from a sand blaster in the primary piston, no rust. The pistons, seals and M/C bore look perfect. I cleaned everything up, honed the M/C and put it back together. The brakes work fine and the pedal isn't as close to the floor. Where did this grit come from? Was it in the M/C when I bought it? When I buy new parts I don't want to take them apart and check them. Anyone else run across this?
68 Vetteman
Old Jul 25, 2010 | 09:53 AM
...Roger...'s Avatar
...Roger...
Probably part of the chrome process , I always steer away from chrome stuff because the quality of what matters is usually overlooked in exchange for bling.
Old Jul 25, 2010 | 12:04 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i've always seen metal particles in my brake fluid reservoir on brake fluid that hasn't been flushed for a year or more. It also takes on that black tint. Just normal corrosion in a cast iron master. All the newer cars have a plastic reservoir and aluminum housing for a reason....i guess.
To Brake Mystery ??
