***1968 power steering pump question***
Old Jul 25, 2010 | 10:57 AM
bkvette3's Avatar
bkvette3
Default ***1968 power steering pump question***
Good day,
Can anyone look at the pictures and tell me if this is a "correct" p/s pump for my '68 L36. Does a '68 pump have a wide or narrow reservoir (where the cap screws on)??? Are there any GM numbers or date codes??? Any differences between a big and small block pump??? If someone could post a picture of a correct '68 big block p/s pump - that would be awesome. Thanks in advance.
Old Jul 25, 2010 | 02:28 PM
PRNDL's Avatar
PRNDL
At casual first glance, that looks a lot like the one in my 68 L-36, but I am mostly recognizing the black peely paint Plus I can't attest to the originality/correctness of mine anyway. And of course mine is well hidden under the generator. Lemme check some numbers...
If you care about this stuff you really should get the NCRS TIM & JG, but hold off, I think they are coming out with a new edition soon. 427 p/s pumps are different, "have a neck that is wider at the bottom than at the top and blends gradually into the body." The cap is black metal with raised letters: Check Oil Hot. Use Automatic transmission Fluid TYPE A. (WTF? how bout p/s fluid? ) Date code is on the cast iron portion of the pump body inside the reservoir. (Not sure if you can see it even with pump off the car. Would be interesting to check in there)
Old Jul 25, 2010 | 03:56 PM
gbvette62's Avatar
gbvette62
Did that info come from the judging manual? I don't think I agree with that. The 75-79 and 80-82 pumps have a tapered reservoir, the 63-74 pumps have a reservoir that is uniform from the cap to the main body. The 1970 parts book only shows one pump for all 66-69 applications. The only difference I know between SB and BB pumps is the BB used the cast, 2 groove pulley, like the one in the picture. SBs use either a stamped steel or cast iron single groove pulley, depending on the horsepower. Admittedly, I am a small block guy, so what do I know!
I can't say that the pump pictured is correct though. 63-74 pumps I've seen have the pipe in the back of the pump come straight out for about a half inch and then take a 90 degree turn straight down and end just short of the bottom of the pump. I would think that the pipe on that pump would position the hose incorrectly. I'm not sure the shape of the reservoir looks right on that pump either. The cap on it is correct though.
You may want to call or e-mail Lonestar Caliper about that pump. They rebuild pumps for most of the Corvette vendors and could probably confirm whether the pump is correct or not. Lonestars number is 903-829-8400, their web is www.lonestarcaliper.com.
Old Jul 25, 2010 | 09:06 PM
PRNDL's Avatar
PRNDL
yep, I just quoted from the book - NCRS Technical Information and Judging Manual. It's a good reference, but not 100% foolproof. Those pics do look like mine... ok, going to the garage with camera.
unfreaking real!! you won't believe this... pics coming
so you know, on a BB 68 with p/s the p/s pump is practically hidden under the generator. Hard to get at, hard to see. For that reason I rarely if ever check the p/s fluid. As long as p/s works and no leaks under the car, all is good. So I go out to the garage, camera in hand to take some pics for this thread, and this is what I see:
Old Jul 25, 2010 | 09:30 PM
PRNDL's Avatar
PRNDL
So thank you for this thread. I have no idea how long I was driving around with the cap off my p/s pump.
At least I had no trouble finding the cap
Good opportunity to check the cap. Based on the description above, it would appear that I have an original cap!
Very hard to get pics of the pump, now that I put the cap back on.
Old Jul 25, 2010 | 10:26 PM
bkvette3's Avatar
bkvette3
Thanks Mark for the photos. Your p/s cap took a lucky bounce and landed in the p/s bracket. I could never be so lucky. For me it would have landed on the pavement - gone forever. Thanks again.
To ***1968 power steering pump question***
