Windshield Install Help Needed...
Old Aug 3, 2010 | 08:53 PM
Emeightch's Avatar
Emeightch
Default Windshield Install Help Needed...
Looking to see if there is a good kit and assembly procedure for installing a windshield. Since the other was broke, I bought a used one. I have also primer'd my birdcage so I'll need the right adhesive and set-up blocks. Is it safe to say just simply center it C/C and keep the same gap at the top?
Old Aug 3, 2010 | 09:11 PM
nd4speed's Avatar
nd4speed
how about this
http://www.speakeasy.org/~pws/Corvette.htm
Old Aug 4, 2010 | 10:36 AM
crvtownr's Avatar
crvtownr
I like this one provided by a another forum member:
1. Remove the trim around the windshield.
2. Fish a piece of high strength steel wire under 1 corner of glass.
3. Pull the wire around the perimeter, 1 hand inside 1 hand outside to "cut" the adhesive.
4. Carefully pick up the glass and set aside, upright. (DO NOT LAY FLAT!).
5.Clean the adhesive from around the frame.
6. Replace all the trim clips at this time, only time you can is with the glass out.
7. Sweep up the broken glass from your cat knocking over your windshield.
8. Call the glass company to install new glass.
Old Aug 4, 2010 | 12:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by crvtownr
...8. Call the glass company to install new glass...
Pro auto glass installers are usually reasonably priced and can install your windhshield in less than half the time it will take you.
Old Aug 4, 2010 | 01:17 PM
Woodsters's Avatar
Woodsters
I thought only my cat did this stuff. Must be from the same gene pool.
Old Aug 4, 2010 | 06:04 PM
Emeightch's Avatar
Emeightch
Originally Posted by nd4speed
Perfect, Thank You!
This is too funny. Here's how I broke the original one. I was trying to get those d*mn clips out!
To Windshield Install Help Needed...
