Frame Question
Old Aug 3, 2010 | 08:59 PM
BWH76's Avatar
BWH76
Default Frame Question
I have been in the middle of a frame off resto on my 76. The frame was completely rotted, it actually broke in half when the body was removed. In search for a replacement frame I purchased 74 or 75 frame of craigsilst. Its been a couple months and I can't remember the year. Now to the questions. How do I tell what year it is? And what will i have to midify to make my 76 body fit correctly?
Old Aug 3, 2010 | 09:08 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
there should be a VIN stamped on top of the rear kick up (I think driver's side?).......if you can read it, look up the sequence or post it here. There are publications that list VIN sequences each year.
Old Aug 4, 2010 | 10:02 AM
Rotonda's Avatar
Rotonda
I know that 75, 76 and 77 frames are basically interchangable though there are slight differences (for instance seatbelt mounting). I am not sure whether 74 is also interchangable.
Old Aug 4, 2010 | 11:01 AM
joewill's Avatar
joewill
since you have your body off your old rusted one and you have the new frame, put them side by side and eyeball them to see the difference, then you will know..
Old Aug 4, 2010 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
VIN derivitive stamped there. Second spot is near #4 body mount. Both are on top of the frame rail.
http://www.71corvette.com/frames.html
Old Aug 4, 2010 | 07:13 PM
BWH76's Avatar
BWH76
Its currently at my buddies shop so if i get a chance i will get down there before the weekend. Thanks for the responses.
Old Aug 6, 2010 | 09:10 PM
BWH76's Avatar
BWH76
OK. So i went down to the shop today. I can't get either spot to read a number. All of the mounting spots were replaced which included grinding around prior, and now there is a thick layer of paint over the entire frame and i can't find the numbers anywhere. Is there any visible things that I could look for as far as design?
Old Aug 7, 2010 | 06:27 PM
stpman's Avatar
stpman
Look at the back of the frame, if the frame is open for a bumper shock to mount in then it's a '75 if it is closed and the side of the frame has a plate for the "one year only" 5 MPH bumper bracket it's a 74
This is the mounting for the 74 5 MPH bumper brackets
Old Aug 8, 2010 | 09:19 PM
BWH76's Avatar
BWH76
I'll get down there early this week and look. Looking at the frame in the pic mine looks nothing like that. At the rear of the frame there are 2 round cut outs that have four bolt holes around them. I believe this is where the bumper brackets mount, and what you are reffering to with the bumper shock mount, which i believe is the canister looking things that have square monting brackets on each end that i removed from the rear of my rotten frame. I appoligize for sounding so ignorant on the topic, and appreciate all the input. Again i will go look early in the week. Thanks.
Old Aug 9, 2010 | 09:12 AM
Rotonda's Avatar
Rotonda
You originally indicated that your frame was a 74 or 75, but couldn't remember. The description you gave of the rear bumper mounting is consistant with a 75. Your 76 body will install on a 75 frame without major modifications.
Old Aug 9, 2010 | 01:59 PM
stpman's Avatar
stpman
Sounds like a 75 or newer frame
To Frame Question
