Spark plug wire choice
Old Aug 4, 2010 | 09:44 PM
psycho dad's Avatar
psycho dad
Default Spark plug wire choice
need to change my wires , probably red or yellow. Anybody have a favorite brand? Also, whats the best plugs?
- Jay
Old Aug 4, 2010 | 10:45 PM
Roughrider's Avatar
Roughrider
Do you have a stock ignition and a stock engine? If so, all you need are stock spec plugs and wires of whatever brands and colors you like. Thicker, low resistance wires are nice though.
If you have headers, you might want to look into really high temp wires...several companies make them...MSD, Accel, Taylor and others.
While I prefer AC spark plugs..their Rapid Fire plugs are excellent, with a stock system any brand plug of the appropriate application and heat range is fine. Buying exotic spark plugs when the system doesn't require them is a waste of money.
Old Aug 4, 2010 | 11:09 PM
fugawi's Avatar
fugawi
i like taylor wires. nice red ones.
Old Aug 4, 2010 | 11:50 PM
SteveG75's Avatar
SteveG75
Accel Spiral Core 8mm with 90 degree boots. I get the universal set and cut to fit so I get the exact length that I need.
Old Aug 5, 2010 | 01:34 AM
jordan89's Avatar
jordan89
I'm running Jegs 8.5mm yellow wires on my '78 Z28 and like them, so I went ahead and installed the same on the Vette. For spark plugs, I went with the Bosch platinums plus. These plugs are good if you have headers since they're a bit shorter.
Old Aug 5, 2010 | 09:53 AM
fdunford's Avatar
fdunford
I have the RapidFire #2 plugs with the Corvette Central data code correct wires and think they are spot on!
http://www.idavette.net/tech/acplugs.htm
Here is a ton of reference information under Ignition Systems.
http://lbfun.com/Corvette/Tech/vettetech.html
Old Aug 5, 2010 | 04:07 PM
psycho dad's Avatar
psycho dad
Thanks for the input guys. Since everything is stock and it doesn't seem to matter, I'll probably go with Accel because they're yellow
To Spark plug wire choice
