1968 Experts ? Question....
Old Aug 4, 2010 | 10:02 PM
dhaile's Avatar
dhaile
Default 1968 Experts ? Question....
Hello All
A good friend of mine had a brand new 68 with 427 vette in High School that I have heard him talk about over the years. (lucky bassturd) He said it was optioned with some rare "vacuum type" throttle that one time almost killed him when it stuck wide open... He said it was only optioned on the 68 and GM discontinued it after that due to so many problems. Does any one know what this "option" might be. He was a teenager at the time and maybe "full" of it... but who knows?
Old Aug 4, 2010 | 11:12 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Throttle is cable operated. Even if the secondaries stuck open, it would just lean pop and die. Maybe it was binding open on him.
Old Aug 5, 2010 | 06:05 AM
Gordonm's Avatar
Gordonm
He is full of it. The two outer carbs were controlled by a vacuum signal but it was not anything special. Just like having vacuum secondaries. The center carb was on a cable. He probably broke the return spring or something like that.
Old Aug 5, 2010 | 09:10 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Sounds like I love these legendary stories from the past Maybe he suffered from a loose nut behind the wheel.
Old Aug 5, 2010 | 09:16 AM
oldsarge's Avatar
oldsarge
Loose nut
Old Aug 5, 2010 | 09:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by dhaile
...He said it was optioned with some rare "vacuum type" throttle...He said it was only optioned on the 68 and GM discontinued it after that due to so many problems. Does any one know what this "option" might be. He was a teenager at the time and maybe "full" of it... but who knows?
I'm sure he loved his '68, but his recollection of a "vacuum type throttle" option is BS.
Old Aug 5, 2010 | 12:20 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...did he also have one of the original "metal" Corvettes too?
Old Aug 5, 2010 | 01:12 PM
markdtn's Avatar
markdtn
How do you start a car that has a choke and a purely vacuum throttle? Anything with a carb will require some throttle to start at some time when there is no vacuum.
Old Aug 5, 2010 | 01:53 PM
PRNDL's Avatar
PRNDL
My 68 had the only factory installed supercharger! But the original owner took it off because the car was just.... too.... scary!
Old Aug 5, 2010 | 01:54 PM
PRNDL's Avatar
PRNDL
please don't interject logic into this thead !
Has a manual override switch for starting!!!
Old Aug 5, 2010 | 02:00 PM
garage-ghost's Avatar
garage-ghost
I get this one all the time.
To 1968 Experts ? Question....
