LS6 Gurus?
Old Aug 5, 2010 | 09:22 PM
LPE385's Avatar
LPE385
Default LS6 Gurus?
Who can confirm for me how many 71 LS6's they made with an M22. I thought it was something like 13 or 18 cars?
Does anyone know the correct number?
Old Aug 5, 2010 | 09:40 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
according to my Black Book, LS6 was a 454 with 425hp and was offered in 1971 and there were 188 cars built with that option it cost $1221.00.There were 130 M22 4 speeds available, 8 of those went into the 8 ZR1's produced and 12 more M22's went into the ZR2's that were produced.So that leaves 110 M22's( I think most went into the LS6's but I don't know for sure.
Hope that helps
Regards
Roy
Old Aug 6, 2010 | 07:43 AM
LPE385's Avatar
LPE385
Hope that helps
Regards
Roy
Thanks Roy I had all that info and I know they made a few Auto LS6 cars too. You could get an M21 with the LS6 so I was trying to find the exact numbers of how many Coupes came with a M22. I had heard the figure some time ago just can't remember it. Thanks for the effort.
Old Aug 6, 2010 | 10:27 AM
60FI's Avatar
60FI
Not an expert, but I don't think you could get a '71 LS6 with M21.
M22 and M40 only.
Much fewer M40's
Old Aug 6, 2010 | 03:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Not a guru of any sort, but from what info I've got, the 71 RPO LS6 was available with the following combinations:
Turbo Hydra-matic with 3.08:1 (std) or 3.36:1
M21 with 3.08:1, 3.36:1 (std) or 3.55:1
M22 with 3.08:1, 3.36:1 (std) or 3.55:1, and special 3.70:1 or 4.11:1 ratios
No info on how many of which, but none came with AC.
Hope that helps.
Old Aug 6, 2010 | 05:06 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
This a question for Warren,aka early shark,he is the the LS6 guy here.
Old Aug 6, 2010 | 05:46 PM
LPE385's Avatar
LPE385
Thank you, thats the guy I couldn't remember his name. I knew there was a LS6 guy here.
Thanks again
Old Aug 6, 2010 | 06:36 PM
PRNDL's Avatar
PRNDL
where is that guru when you need him? There's another one around here somewhere. I learned at the NCRS national that LS6 have a fuel return line, unlike every other Holley carbureted C-3 that I can think of. Got to look at 2 of em.
Old Aug 8, 2010 | 01:42 PM
LPE385's Avatar
LPE385
Bump
Old Aug 8, 2010 | 07:05 PM
early shark's Avatar
early shark
122 of the 130 M22 transmissions were installed in the 1971 LS6 ordered cars. The breakdown that we are unsure of is between the M21 ordered cars and the special high shift Turbo 400 transmissions.
Approximately 34 to 36 LS6 engines were coded for automatic transmission usage. We currently have 16 M21 ordered LS6 Corvettes located so far.
It's not confirmed yet, but it appears that all the M21 transmission LS6's did not come with the MA6 heavy duty clutch, all M22 transmission LS6 did have this clutch assembly.
Old Aug 9, 2010 | 03:09 AM
jr9170's Avatar
jr9170
Great info as usual Warren...
To LS6 Gurus?
