I have two sets of coil springs for the front suspension. One set is for a 68 small block coupe. The other set is for a 69 big block coupe. My problem is that I do not know which set is which. And I want to put the small block springs on my car. Is there a way to tell the differrence? Such as diameter of the coil. Or thickness of the metal coil? Or even the height of the spring?
I would not want to put the big block springs on my car that will have a small block in it. This would probably raise the front of the car by a couple of inches and make it look wierd. Any ideas?
wayne h.
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
wayne h.
After you figure it out...........
If your not using the big block ones let me know i'm interested in buying them. New ? used ? original ? more info if selling........please !
The wire diameter should be different between the two. The big block springs will have a higher spring rate so the wire diameter should be greater than the small block units.
