oil pressure sending unit
Old Aug 8, 2010 | 05:59 PM
relic1864's Avatar
relic1864
Default oil pressure sending unit
Where on the engine is the oil pressure sending unit on a 1976 Corvette located?
Old Aug 8, 2010 | 11:27 PM
myoriginal77's Avatar
myoriginal77
Back of the intake on top, should have one wire coming off the top, if it hasn't been changed it should be like a little can about 2" in diameter, screws in.
hope that helps,
Frank
Old Aug 9, 2010 | 01:54 AM
snoopykissedlucy's Avatar
snoopykissedlucy
My 1976 Corvette has the oil pressure sender located just above the oil filter.
Old Aug 9, 2010 | 06:24 PM
427basketcase's Avatar
427basketcase
Most small blocks will be right by the distributer, in the rear of the block,
On a big block it will be in the left side of the block just above the oil filter
Old Aug 9, 2010 | 07:25 PM
...Roger...'s Avatar
...Roger...
I know 77,78 and 82s had it just above the oil filter. I have seen the sender up behind the intake at the back of the block , don't remember if it was stock or moved because the oil filter spot was used for a shutoff for a fuel pump.
Electric oil gauges started in 74, maybe they were at the top. Can't remember.
Old Aug 10, 2010 | 06:31 PM
jlaw68's Avatar
jlaw68
My 78 and a friends 82 both have the sending unit above the oil filter, but my 71 Nova and 72 Chevelle both had them on the back side of the intake by the distributor. All are small blocks.
Old Jun 13, 2011 | 12:32 PM
bobs76stingray's Avatar
bobs76stingray
Default oil sending unit
My 76 Stingray oil sending unit is over the Oil Filter also
Old Jun 13, 2011 | 12:49 PM
SteveG75's Avatar
SteveG75
'75 above the oil filter.
To oil pressure sending unit
